1 - 20 of 29 Posts
I'm looking at a turbo upgrade. Is there a way to tell if the turbo being sold is a real MHI turbo? Is there a way to tell if it's a small or BIG 16g?
If you google a picture of an evo 3 turbo you will see it says tdo5 on the compressor housing. Also the fake ones usually have like a tag on it that says evo3 turbo on it or 16g on it. The real ones don't have that. It says the tdo5 and has the serial number on it.
Jon has a good point. I remember looking at a car that had a "real" 16g on it. Once looking at the turbo I saw it had a tag on it that said "DSM 16G." If you see anything like that, run and hide.
Do you guys know the difference between the Evo III 16g and the Big 16g? Are they the same thing?
As the name implies, the Evo 3 16G came on the Evolution 3 in Japan (and else where). It is a bit bigger then the regular Big 16G.
Blurred: Turbine/compressor housing pic.
I see it, oops, brain fart.
Discussion Starter #12
I guess I should have asked this to start off with. Is the Big 16G the best street turbo? I'm not really looking to make huge power gains. I just figure that if I have to replace my turbo anyways, I might as well upgrade to something that's a little more fun.
Discussion Starter #16
I guess what I really meant was am I going to be doing any harm by not tuning it for awhile. I plan to get OpenPort and playing around with it but it could be a couple months before I feel like I'm comfortable with flashing my ECU.
By just .010", or the thickness of two sheets of notebook paper.
The difference is the better-flowing high-nickel turbine housing which doesn't crack, and the compressor wheel itself on the Evo III has thinner blades and a smaller "hub" area. This makes the compressor both lighter and better-flowing.
What he said. I have a big 16g but may still upgrade in a bit.
I wouldn't run the evolll big 16g turbo without updating other parts.
255 Pump
I used 680cc Injectors
I also put an aftermarket fuel pressure regulator
Tune!
1 - 20 of 29 Posts
