1 - 8 of 8 Posts
I think there is a leak in my AC at the evaporator. I have been told the only way to get to it is to remove the dash and it's somewhere behind the passenger glovebox. Is this correct?
Of course I will make sure the leak isn't elsewhere before going for the evaporator. I just want to make sure there isn't an easier way, for instance can I just remove the glovebox and airbag?
I was suprised there are only 5 threads on this whole site with the word "evaporator" in the title, and none of them have info on how to remove it, nor does VFAQ. Someone must know.
There are threads somewhere on here about it....don't just use one keyword, that won't always work.
There was a guy in sweden not to long ago, and he ripped up his dash. It was a 1g, but I think they are similar, if not the same. Either way, he did some really cool stuff with what he had, took a bunch of stuff out, bla bla bla. Maybe you could search for that thread, it may help you....
OR you could get a Haynes or Chilton, which would surely tell you the answers.
Mabe on a 1g but on a 2g its not hard at all, from what I remember.. Get a manual and save yourself a headache.. The dash does not have to come out, just the glovebox if my memory serves me right..
Skywise said:
Yeah, I was referring to 1G. If a clogged drain is still the issue you can sometimes use a coat hanger from underneath to poke out the debris, but you need to be careful not to dislodge or pierce the drain hose.
That was my problem when I replaced mine, damn might have been able to save money.:chair:
1 - 8 of 8 Posts
