1 - 6 of 6 Posts
Just installed SD and dialed it in some, but could use help smoothing it all out.
This log is the last pull I've done and I have NOT made any adjustments yet.
Take a look if you don't mind, any help would be greatly appreciated.
Honorary Moderator
What fuel are you using?
There are major jumps in the VE that are causing major jumps in the tune, which is obvious. If you'd like I can make you a smoother VE table and clean up both the open loop and timing tables as well.
Discussion Starter #4
Thanks again for all the help Mindblowin03!
^^Already w/ the spam. Is verticalscope good at keeping spam off the communities they acquire?
1 - 6 of 6 Posts
