I have a '95 Talon ESi (stock).
I just had the clutch replaced about 2 days ago, then tonight on the way home my Shifter goes dead stick on I-459. I had to drive all the way home in 5th gear without stopping. What i want to know is Has this happened to anyone else. Your clutch go out then 2 days later ur Shifter messes up and comes detached. Does it have anything to do with the clutch at all. Im very new to DSMs so i dont know much. Any help at all, ill be greatfull. Thanks
D
Most likely, its because of the clutch install. I am assuming you had it installed at a shop, so they would be liable for this problem.
A good rule of thumb is.....if you install something on your car, and something goes wrong, it is because of a that product or a bad install.
Check the bracket on the transaxle. I had something similar happen to me on my last clutch install. The bolts came out of the bracket, and all I had where 3rd 4th and5th gears. I was *SURE* that I had tightened everything, but I guess I missed that one. One of the bolts had fallen out, the other one wasn't far behind. Luckily, the bolt that had fallen was lying on top of the tranny, all I had to do was just put it back in and tighten them both down. Hopefully, this is the problem you have.
Scott
DIG through the ditches, and BURN through the witches, and SLAM in the back o' ma' DRAGU-LA-AA!
