http://www.4g63turbo.com/tech/4g63-camshaft-degreeing.html
Read this link.
Read this link.
You can either buy a few home-made solids from Forced Performance or make a few solids out of OEM lifters. If you want to run them as appose to just using them to degree your cams the shim type are by far the better choice.Thanks, I saw that one already. Just before step 4 it states "The preferred method is to use solid lifters(nut adjuster type). You can accurately adjust the lifters to have .001" preload, which can not be easily done using shims."
So I'm looking for the "nut adjuster type" of solid lifters, as they're easier to use than shims and can be adjusted more accurately.
Good link. Great info to have if you don't already know.
The BLE's are actually perfect for cam degreeing. Much easier and quicker than trying to use shims to adjust out lash.You can either buy a few home-made solids from Forced Performance or make a few solids out of OEM lifters. If you want to run them as appose to just using them to degree your cams the shim type are by far the better choice.
The jam nut type offered by BLE are junk.Why spend several hundred dollars on something that your going to use once? Just use some OEM HLA's. BLE's are really junk. This is coming from myself and my machinist. Had them in a motor that was built in our shop. The jam nut is a PITA. Shim type are a lot less of a headache.
Tomei makes solid shim type lifters. They are not cheap,but thats what I would run if I was going solid.
If you get yourself a decent set of cams you really don't have to worry about degreeing them. Degreeing cams is like quality controll. It's more or less to assure the cams specs are dead on,and to assure everything will orchestrate correctly. I dropped in my Kelford's and never looked back.
LOL! Not likey, I'm just as strapped for cash as the rest of you! And with :tree: around the corner...:dunno:OP - It seems that about every year, someone buys a full set and sells them as pairs in the forum classifieds. Maybe you could be that guy this winter?![]()
I'd have to disagree with youthere.I don't like the design of the BLE's. They are not eay to adjust properly. Like I said,I built a motor a few years back for a friend of mine using BLE solid lifters.It's much easier to accurately set lash with shims. There is not lock nut to worry about.You get your shims in there and thats that . It's just that the jam nut type would definately not be my first choice though due to the price. I just use modified OEM lifters to degree.The BLE's are actually perfect for cam degreeing. Much easier and quicker than trying to use shims to adjust out lash.
To degree cams,ok. I could see using the BLE's. But at the price they are, Big Len must be smoking some good shit. When my shop was doing quite a few 4G63's we looked into buying some sets of BLE's. Len was only willing to drop the price a few bucks per set on a pretty large order. Needless to say I'm glad we never did anything with him. We just use 1G modded lifters now when it's absoluetly necessary. I mean did you read some of the horror stories from other BLE lifter users?The BLE's are actually perfect for cam degreeing. Much easier and quicker than trying to use shims to adjust out lash.
Degreeing cams is what this thread is about. Nobody is asking about running them in an engine.To degree cams,ok. I could see using the BLE's.
Link? I'd like to see how they modify them.OP, There is a guy that works at Forced Performance that sells the modded oem lifters for degreeing. You don't need a full set.
Just friggin' call them. I just happened to be BS'ing with a guy from there and he said he keeps some to sell to customers. It's not that difficult. Just google it. I'm sure you'll find a thread somehere.Degreeing cams is what this thread is about. Nobody is asking about running them in an engine.
Thank you for the link!Demon33 - Perfect timing: http://www.dsmlink.com/forums/showthread.php?t=54103
Anyone know where I can get a set nowadays? I can't seem to find a pair anywhere.
Jordan
