1 - 8 of 8 Posts
If he bothered to put so much info and pics I'd say he's legit. Not too sure on the intercooler though..piping looks bad ass...
totaleclipse_05 said:
3" piping is VERY unnecessary.
Is it? I run 3" piping, and I feel it is totally necessary. Put some thought into your comments. Not everyone needs 3" piping, but there are some that do. Who knows, the OP might be wanting to use this setup for a turbo with a 3" outlet, would it still be VERY unnecessary?
Discussion Starter · #5 ·
How fast are you running or any HP rating? and what kind of turbo do you go with? It's nice to know someone else having 3" piping setup. these are definitely over 500 hp if not 1000.
2.5 inch intercooler pipeing is good up to 600 horsepower. Under that much horsepower you will loose torque and spool up time with 3 inch pipeing. It's just overkill to do 3 inch intercooler pipes if you have a set up with less than 600 horsepower or so.
My new setup is using a 24x12x4.5" Garrett core with 3" piping coming off of a Borg Warner S374. The turbo is capable of over 1000whp, I don't know when I'll push it to the point. I highly doubt my eagle/wiseco combination will hold up. I plan on keeping it around 700whp this year.
You dont loose anything with 3" piping from 2.5" piping. as someone mentioned. I am talking about turbos over a 60 trim though. I have not tested anything smaller.
I have tested both by the way. 3 " piping is good but I have not seen any performance increase with just that. It allows though to have smooth transition tubing to a 3" TB. I say run 3" piping if you plan to run a 3" TB.
At the same time, Curt Brown has gone mid 9's on 2.5 piping and a 2.5" TB.
Goodluck!!
1 - 8 of 8 Posts
