1 - 10 of 10 Posts
I have looked through every single part I have in every single box and made this inventory (it actually took a few days lol).
If it's not on the list, I do not have it.
Look carefully as there is a lot of stuff. All parts are 1G specific unless otherwise noted. Items are located in Ontario, Canada and will be mailed out from here unless otherwise noted.
Items with a ** next to them have been recently replaced and have very low KMS! (less than 5,000 miles!!)
Engine
- New 2G head, the previous owner of this engine had it rebuilt. It's very clean, however it has one (1) slightly bent exhaust valve on the #2 cylinder, from what I assume was debris when the #2 rod/piston blew. – Best Offer
- Stock Turbo camshafts, 2 pairs - $30/pair
- ‘3G’ revised lifters ** - $80
- OEM Rockers - $10
- Black Taylor 8mm spark plug wires ** - $40
- Aluminium radiator ** $150
- Wrinkle Black valve cover - $40
- CAS x2 – one “black top”, one “green top” - $40/each
- OEM 1G Knock Sensor ** - $100
- OEM 2G Knock Sensor - $50
- Denso 1G o2 Sensor ** - $50
- 12" slim rad fans ** one slightly used - $30 one BNIB(comes with mounting kit) - $50
- OEM water pump - $20
- Turbo water pipes x2 - $10/each
- Turbo thermostat housing - $5
- OEM lower and OE Upper Rad Hoses ** - 50
- OEM Heater Core hoses ** - $40
- 91-94 Throttle Body w/ TPS. TB is seized and needs a rebuild - $10
- AC Delco alternator belt - $5
- OEM Crank pulley (harmonic dampener) - $40
- OEM Water pump pulleys - $10
- Power Steering Pumps x2 - $20/each
- MT Starter - $50
- OEM Non-Cruise throttle cable ** - $50
- Coil Pack Igniters x4 - $10/each
- Coil Packs – x3 1G coil packs, and one 2G coil pack - $30/each
- Custom coil pack bracket for SMIM, w/ coil pack & igniter. Ready to bolt on and go - $50
- 1G Driver side & Passenger side Prothane inserts in silver powdercoated mounts - $50
- Stock 90 oil cooler – no lines - $5
- Stock 6 bolt rods & pistons - $50
- Stock 7 bolt rods & 9:1 1G NT pistons - $30
- 6 Bolt AWD oil pan
- 6 Bolt OEM front case
Intake & Exhaust
- Custom 3" turboback. ** recirc o2 elininating downpipe, catless, has bung for primart o2 in stock location as well as bung for a WBo2 further downstream. Comes with a can muffler. Looking for $200 for the whole thing. Pick up only.
- Rubber 1G intake pipe - $5
- BNIB paper air filter 1G ** - $10
- Stock 1G SMIC- $20
- Stock turbo outlet (J) pipes x2 - $5/each
- 1G BOVs – one is crushed, the other has the “Dodge Garage Mod” done - $20/each
- 2.5” universal Ractive muffler & tip - $40
- Stock 1G n/a muffler and tips – I used it as a “decoy” when I ran open downpipe last summer. In great shape - $5
Turbo
- Ported 2G exhaust manifold - $50
- Manifold heat shield - $10
- TD05H 14B turbo - no smoke, no in/out, normal side/side - $50
- Aggressively ported 7cm^2 hotside with upgraded 34mm flapper, slight cracking - $60
- Stainless Steel J-Pipe - $80
Fuel
- Inline Walbro 190LPH fuel pump w/ -6AN fittings ** - $60
- Purple Fuelab AFPR (-6AN) w/ fittings ** - $150
- Purple Fuelab fuel filter (-6AN) ** - $80
- PTE 780cc Injectors w/ new seals - $180
- Stock 450cc injectors - $20
- Injector Resistor Packs, x2 - $10/each
- About a car-length's amount of -6AN stainless fuel lines, with various straight, 90, and 45 male and female hose ends ** - $100
- Fuel Rails, x3 - $10/each
Drivetrain & Transmission
- ACT 2100 pressure plate - $50
- 7-bolt AWD Fidanza Flywheel w/ pressure plate studs - $100
- Stainless braided clutch line ** - $30
- OEM Clutch Master ** - $120
- OEM Slave ** - $80
- OEM TOB ** - $30
- OEM Clutch Master – good core for a rebuild - $20
- Wagner OE Clutch Master ** - $40
- Driver-Side Half Shaft (dummy shaft) w/ carrier bearing - $50
- Passenger Side Front remanufactured axle - $50
- BNIB Extended slave rod ** - $10
- OEM Pivot Ball ** - $5
- BNIB CV Boot Kit ** - $15
- BNIB SouthBend TOB ** - $20
- BNIB Axle Seals ** – MD719710 (AWD Driver Side) & MD707184 (Pass Side AWD, early FWD, or rear AWD) – $10/each
Suspension & Brakes & Wheels
- 97-98 2Gb Talon 17" swirlies with 215/45/R17 General Exclaim UHP tires, 50% left - $150. 3/4 rims are good, the 4th is damaged. However I have a 5th true wheel to replace the damaged one. - Pick up only
- 5x114.3 Spare Tire - $5
- Baer 13" BBK for the fronts, cross drilled rotors and big 2-piston Baer (PBR) Calipers loaded with pads. 40% pad life. Wicked setup - $550
- NON SEIZED 1G AWD black rear calipers. Comes with pads and rotors ** - $300
- Set of black stainless steel braided brake lines for all 4 corners ** - $50 per pair or have them all for $90
- 2G non-ABS prop valve - $20
- Complete Brake hard-line Set for non-ABS ** – Uses EZ Bend lines and all the matching fittings and flares. Comes with: 2 brake master to prop valve lines, 2 prop valve to front brake lines (L & R) and 2 prop valve to rear brake lines (again, L & R). Already flared, no leaks, ready to be installed and go. – Asking $150 for everything
- 3mm wheel spacers x2 - $15
- 5mm wheel spacers x2 - $20
- KYB GR2 front struts – good shape, non-blown - $40 for both
Electronics & Monitoring
- ECMLink V3Lite w/ socketed 91-94 EPROM ECU ** - $550
- Virgin 91-94 EPROM ECU – Needs work - $40
- 91-94 Non-EPROM Turbo ECU - $80
- 91-94 Non-Turbo ECU - $20
- 30 PSI Autometer Phantom boost gauge ** - $30
- Evo 8/9 "399" MAF and pigtail - $120
- 1G unhacked MAF with filter - $20
- 3” GM MAF - $10
Interior & Exterior
- Stock battery tie-down - $5
- Stock battery box - $5
- BNIB 1G hatch Struts - $50
- 94 Casette + equalizer + AUX radio - $10 (Aux is nice for playing music off your iPhone 6 through a 20+y/o stock radio) tongue
- 90 Casette + CD Player radio - $10
- Wiper Arms, sandblasted and painted black – 2 front, 1 rear - $20
- Rear functional wiper motor - $20
- 90 Gauge Cluster- 237,241kms - $20
- 91-94 Gauge Cluster – 236,237kms - $20
- HVAC Controls w/ cables x2 - $10/each
- Stock 1Gb head lights – x2 pairs - $20/pair
- Stock 1Gb side marker – Driver side - $10
- Mirrors – x2 passenger side mirrors, one black one white - $10/each
- Various small knobs, switches, etc for a 1G – Inquire
Hey ill take the Turbo water pipe an Stock 90 oil cooler
Interested in the TD05H 14B turbo an awd oil pan any pics?
Got a photo of the front brake setup? I assume that it comes with the bracket so that it will mount to either a 1g FWD or AWD, correct?
Pictures of the virgin E-PROM?
Discussion Starter #5
Hey guys,
I had an accident which left me with a broken right knee and right collarbone. I can't even walk, let alone do stairs. So the partout will have to be put on hold for a few weeks until I can do basic human things and not be stranded in bed.
I apologize for the inconvenience. I will keep this updated as I recover
Lucian
Holy shit, dude, I hope you're okay. And tell me it wasn't in the UEL header equipped Hyundai!
Fuck the partout, just get better dude!
Hi, Do you still have oem 94 am/fm double din radio with equalizier?I have I think the same one in my 93 gsx, its made by Mitsubishi.Is your the same? My cassete player works but not the radio. Please reply here or [email protected] or call 501-691-1025 ask for Crist.I live in Drasco,Arkansas 72530 THANKS Christ Linkis
Hope the recovery went well. Where abouts in ontario are you located? I am interested in the non cruise cable. Most likely good for a pickup cash in hand deal.
1 - 10 of 10 Posts
