Dear fellow DSMers,
exactly what's described in the subject.
I usually cruise with the 'Sens. Check' screen to monitor my O2s, but sometimes I play around and switch screen over to the pretty Throttle and RPM gauges...
Well, sometimes the Throttle position doesn't work. Has this ever happened to any of you before? I am 99% positive that the S-AFC installation is correct, I soldered extremely carefully all the connections, and duct-taped the whole thing for protection.
Could it be maybe some stock sensor on my car that needs to be replaced? Sometimes it works, sometimes it doesn't. I would say that most of the times it does work.
Thank you all for any advice.
Walter
Walter
