1 - 20 of 28 Posts
I did search for about 45 mins but no luck on this particular problem. Here it is! Car starts, car drives, no problem!! Shut car off, turn ignition, EVERYTHING goes dead, wait a while, disconnect batt., something resets? car starts, runs, drives.... Repeat!
I have checked all connections, grounds, and fuses I can find. Took battery cables off cleaned throughly and reinstaled. I don't know if it is reseting due to the battery being disconnected or just due to time, but in any case I am lost!
Also when I was pulling fuses, there was one 10 amp fuse (ROOM/PLAFON) that when I pulled it the door buzzer started working again but only till the fuse was plugged back in. WTF!!! could this be somthing to do with the anti-theft system?? And if so where do you start to check that? I couldn't find anything helpful in my chiltons.
Discussion Starter · #2 ·
No thoughts??? I was wondering if the ECU could be the problem? No fishy nasty smell but I don't know what else to look for! Any help would be very much appreciated.
Discussion Starter · #6 ·
No turbo timer! I am at a loss... Don't know where to go from here! Also an added bit of infromation, after it resets, sometimes it will show lights and door buzzer will work etc.. Till I turn the key to start and then it all goes dead again.
90gen1tsi said:
If it is a relay would that cause everything electrical to cut out?
It's possible if the relay is activating a short. When you turn the key to start the car the starter relay is supposed to close it's internal switch allowing current to flow from the battery to the starter. It could be a short in that wire or it could be an internal short in the relay.
Bad relays can be tricky too. Sometimes the problem goes away if enough time passes, due to expansion and contraction of the element creating the short for example.
Here's an example of all the things that can go wrong with the main EFI relay (in a Honda). http://www.tegger.com/hondafaq/mainrelayoperation/badmainrelay.html
The variety of symptoms it creates could have you analyzing the entire car before you figure it out.
Then again, maybe it isn't even the starter relay at all and it's a loose ground like Burnett said.
Discussion Starter · #16 ·
Once again thank you for the help! I have checked and re-checked the grounds and battery connections to no avail! I may be missing a ground somewhere though... I caught a ride to work with a friend today and will continue the search when I get home. Now the car is totally dead! Usually after some time it will act normal again but this time it has stayed dead. I have not disconnected the battery this go around yet. I will try that again when I get home.
Check your MPI relay behind the stereo by the ECU. It sounds like it's latching and not de-energizing. Mine took a dump after I got a tune finished. I went to start it to pull out and the bastage was fried. I'm just lucky that my buddy had a spare one.
Discussion Starter · #18 ·
I have been doing some searching and it sounds like the MPI could definatly be the issue! Is there a good way to test this? I will keep searching, but if you know that would be great!
I had something similar. I needed to tighten up the battery cable on the termainl of teh battery, like using a wrench instead of hand... it fixed my mystery problem. HOpe it helps.
Discussion Starter · #20 ·
F-ing dealer parts place is useless... They don't even know what an MPI relay is and won't look it up for me... they want me to bring the part in!!! This is getting frustrating!!!!!
Oh and I alreay cleaned and tightened the terminals with wrenches.. Thank's though!
1 - 20 of 28 Posts
