Need some places/ideas to look on this situation. I go to turn the key to start it and it just clicks so i turn it a few more times and same thing, then about the 5th time the starter turns the motor over and starts. Most of the time this is how it will start when it acts up, For the most part though the car will normally start like normal. Then there are times where no matter how many times you turn the key it will not start at all,all you hear is click,click .
Now for the things I've done to try and correct the problem.
1) Turbo timer harness took out the plug n play harness and squeezed down the terminals,(that didn't work so i hard wired it in, soldered all connections).but still didn't fix it.
2) Starter is new (discount brand) i know
3) new starter Power/Ground harness (dealer)
4) Cleaned all connections
5) Changed out starter relay under dash in junction block.
6) Took out the anti theft relay
7) New ignition switch harness (dealer)
8 ) Both coolant sensors are new
I think that's all.
I guess i should mention that when it acts up and will not start,to start it in this condition all i have to do is get a jumper wire and put one end on the starter terminal and the other end to positive on battery and it starts right up.
At this point im just about out of options and ideas .
I think that's all.
