Stephen's Talon and Laser.
1995 Eagle Talon TSi AWD 5speed. 140k Miles(150k miles 12/3/2011)
Factory Options:
Leather seats, Premium Infinity Sound system, Sunroof, Anti-lock brakes, All wheel drive with rear limited slip differential, 16" Alloy wheels, rear deck lid spoiler, large rear vented brakes.
Engine:
8.5:1 Ross Racing Pistons, Eagle H-beam rods, removed balance shafts and a lightened crank in a .10 bored over 6 bolt 4g63 block(no oil squirters or cooler). Removed A/c.
Head and Intake manifold:
Hks 264/272 Cams with a 1g intake manifold to the original port-matched head with a 60mm 1g throttle body. FIAV(Fast Idle Air Valve) removed. Head is sealed to the block with a Mitsubishi 4 layer metal headgasket and ARP head studs. Fancy Rubber Viton valve seals. Thermalic spacer.
Turbocharger and Intake:
Ported FP Big28 turbocharger 15psi-22psi depending on the situation
. RRE intake and upper intercooler pipe with a 1g Blow off valve. RRE Upgraded throttle body elbow. Greddy "Big" Front mount intercooler, no-name air intake system with home made heatshield. Slightly gutted maf with adjusted airflow screw. RRE Lower S-pipe and RRE Greddy lower U-pipe upgrade pipe.
Exhaust:
Forced performance manifold, 122 performance 02 dump, Stock exhaust with cut-out.
Drivetrain:
ACT Xact flywheel, Centerforce Dual friction. Shortened shifter and a symborski shift kit. Cable to transmission bushing upgrade. Greddy counter-weight shift knob. Stainless steel Clutch line with restrictor unit removed.
Fuel:
Rewired Walbro 255hp. Streetuned motorsports tank to line kit and Fuel lab fuel pressure regulator kit. RC 1000cc injectors
Suspension:
Front and rear Strut tower bars. 1998 17x6.5 alloy Eagle Talon wheels with Continental Extreme Contact 215/50/17, ugly but good. AGX 4-way adjustable shocks. Eibach pro-kit springs. RRE rear camber kit.
Brakes:
Drilled and slotted rotors. Ect brake pads.
Gauges and Electronics:
Dsmlink V3, Aem Tru boost, Aem Wideband. Removed Clutch start switch and a 90 Crank angle sensor. Pioneer Mp3 player head unit, 10" mtx subwoofer and amplifier.
Body modifications:
1998 Front bumper upgrade with anthracite emblem, 1998 rear spoiler and brake light on original rear hatch. Talon rear centerpiece lights up(Tarantula). Super cool green backup lights
Car 2
1990 Laser Rs Turbo M/t 103k
Factory options:
Light as hell.
Engine:
ARP headstuds. A/C removed. prothane motor mounts. Non-Cruise control cable.
Turbocharger and intake:
Straightline specialties Upper intercooler pipe.
Slowboy racing fmic
K&N airfilter.
Manual boost controller.
2g Maf and intake pipe.
Drivetrain:
Act 2100/Street disk.
New Awd half shaft/axle.
Stainless steel clutch line.
1970's bare foot gas pedal upgrade.
Shifter bushings and 3000gt shift knob.
Fuel:
Brand new Gas tank. with 255hp(Sitting in my garage, not installed)
Suspension:
Eiback pro-kit springs
Agx 4-way adjustable shocks
Gauges and electronics:
Boost gauge. Blitz electric boost controller.
Body modifications:
Stock black hood.
Oz edition eclipse 16" wheels.
