1 - 6 of 6 Posts
The stock boost control is basically a bleeder arrangement. Fine for stock boost, but it spikes once the boost is increased through intake/exhaust upgrades.
Discussion Starter · #3 ·
On the buicks, i run dual solenoids with a electronic controller. I also enlarge the wastegate hole to 1.20 and change the housing puck to a 1.25". I have a solid control of14-30psi of boost +/- 1.0psi. I'm thinking these mods would apply to DSM too.
What do most of you do, go external gates? I've had experence with HKS, Turbonetic delta and race gates.
Mike Smith
87 Buick Turbo
[email protected]
www.turbomike.com
I think that most DSMs either get their internal waste gates ported, have enlarged flappers, use the Super 16G or 20G (which is basically a modified internal wastegate arrangement guaranteed not to boost creep), or go with the external route.
This usually goes with having an electronic boost controller or something that a lot of fast DSMs seem to use are ball-spring type manual boost controllers.
Sounds like you have a fast buick, what times do you run?
Heh, 11.3? Now that's fast :). Was that with slicks? I guess since you're looking in this forum a possible project might be a DSM?
One thing that always concerned me with highpower RWD vehicles is driving in the rain. Did you have much problems with that?
1 - 6 of 6 Posts
