1 - 2 of 2 Posts
Ok this is not DSM related but, Z seems to know alot so here goes. I am building a system for a friend and so far we got 3 12w6 JL Audios and a PG ZX500 amp, I am running it at a 1 ohm load. How can I get the best DB readings at Comps? This installer said not to install any noise dampener if I was only going to DB drag the system beacsue rattles are still noise and that is what I want. Is this right?? I am trying to get at least high 150s. With just the radio to the amp I should be hitting 148-150 so what would help out as far as a processor? I ran a AudioControl EQQ with 2 10w3-2 and the same amp in a 240sx and hit 147db. So what you think?
He's right aboutthe rattling it does boost your Db's. Processors useally hurt your score but, it really matters try it with and without the processor if you hit 147 with the same set up in a 240 then you should be able to do it
1 - 2 of 2 Posts
