K im replacing my t-belt and the special tool that I need to apply pressure on the auto tensinor. Is there any way of using something else or where could I find one/ maybe borrow?
I use a 12 inch pry bar, it works fine. after you set the tension make sure you rotate the crank atleast three whole revolutions . Then recheck the tension.
