1 - 15 of 15 Posts
Hi, this is a great forum i have an 1991 Eagle Talon Tsi turbo AWD in limp mode, I checked the tcu for those damn faulty caps and found that some chip inside was burnt, I live in ensenada mexico, and i was unable to find the part on this side of the world... :dunno:
so i was wondering if some one can post a picture so i can try to rebuild the tcu and hope to get running soon!
by the way the part number is MD920075, thanks!!!
Discussion Starter · #9 ·
ok its burnt pretty bad, now i need a little help, can someone post a pic of a good tcu, so i can try to fix the hole from where C24 is? I know its going to be hard to try and fix this thing but its a good challenge.
ok its c112, c24 and maybe c25 that got fried.
thanks for youre help...
and I hope that rule number 7 wasnt for me... if it was sorry...
Are you sure you don't mean MD750092 ?:)
Discussion Starter · #11 ·
Thanks that will help a lot!!!!, and yes i got it wrong that time it's the md750092, I just hope i can do some crazy stuff to fix the board and get those gears back... i will try to post back!!!
Thank you very much GDNF2ET!
Here's a better pic..
Discussion Starter · #13 ·
ok, I have fixed a few things, but i think something is still wrong, just wondering there are some smd caps a small one and a medium size one next to the c112 cap, do u know the specs of them? do both have the same 0.1mf's 50v?
The only thing right now that has changed is the A/T temp light finally has turned off, but not all the time its like i still have some details to fix... and yes limp mode is still there...
Check the main fuse panel in the car on the drivers left side...Look for the 10amp fuse labeled
(4A/T)
(BOITE AUTO)
If its blown, you will be in limp mode....
Maybe the problems you had blew this fuse...
Discussion Starter · #15 ·
ok, there was no blown fuse there, i think my tcu is done, well at least i cannot test it in a few more days, my head gasket gave up on me... that sux!, ok I will try to test it maybe next week when my car is fix... if it was just the head gasket..
1 - 15 of 15 Posts
