1 - 12 of 12 Posts
I have a 1G head that i am working on. I have pretty much everything taken off and cleaned, but i am not sure if it had bent valves or not. is there any way to tell if any valves are bent with out taking the valves or valve springs out?
I just rebuilt my head after a leakdown test showed bent exhaust valves. Anyways I couldn't tell if they were bent or not, you have to take it to a machine shop and have then either pressure test it, or take it apart and check the valves for staightness.
Actually I got a brain wave here, maybe if you were to put water in the intake and/or exhaust runner and see if water leaks out from the valve. Just make sure your cams are out so the valves are all pulled in.
actually, thats a good idea. i think that might work. its genious!
Discussion Starter #5
ok thanks ill try that tomorrow and let you know. what kind of alcohol should i use. will rubbing alcohol work?
Yes that is the best!! Let it set and see if the leak. Do you know anybody with any pistion rings, I NEED SOME ASAP. I would prefer them new
Discussion Starter #8
Well i tried alcohol on it, no leaks whatsoever, so i guess the valves are ok. Also the head looks amazing now, pretty shiny silver. ill post some pictures later.
how long did yo ulet it sit for, sohuld of let it sit for at least 30 min, and did you do Intake side too?
You can tell if you have a Burnt/Bent exhaust valve.By holding a $1 bill in your exhaust tip.If it want's to suck the $1 bill into your exhaust,then you have a Burnt/Bent exhaust valve.....just a mechanic trick....
That trick with the dollar bill is really cool, i'm gonna remember that, thanx :)
Discussion Starter #12
I could put a 1 dollar bill up to my exhaust tip, but that would be pointless since the head is sitting in my dorm room. Yeah i let it sit in there for 15 minutes and did the exhaust and intake valves and it didnt leak
1 - 12 of 12 Posts
