1 - 6 of 6 Posts
Is the 1g 14b a water cooled turbo? If so, can you explain where the 2 water lines would hook up to the block/water pipe?
Thx
Jay
Yes it is water cooled. One line connects to the main water pipe right behind the turbo and the other connects right above the thermo housing.
Thanks! LoL.. I noticed my 6 bolt motor doesn't have the water fitting that goes right into the block like my 2g does. Thought I would do a little research on it.
Site Administrator
when i did the 6blt swap i had to do some custom welding for that water fitting for the turbo.
Site Administrator
Yeah, i took the 2g water pipe (cus it was cleaner in my case) and cut off a 2" square around the banjo line on the 1g pipe, removed that whole section and welded it to the 2g pipe, drilled a hole to allow the water to flow through the new fitting.
1 - 6 of 6 Posts
