My grandfather and I removed and reinstalled a new clutch on my 2003 eclipse gt 3.0l and when we finally got the bellhousing put pack together with the transmission we couldn't get it to start tried a new starter tried to start but only clicked but no crank checked the battery for surface charge not an issue check for power draws no issues check the starter at autozone comes back good checked relays those are good finally got it to start after jumping the positive terminal on the starter now we can start it without issue but can't be put into gear inspected the bellhousing again and I think the spring fell out of place it helps hold the fork that holds the throwout bearing is there any chance I can get away with getting it back into place without tearing apart the bell housing again all help is very much appreciated just trying to make up my mind if I just want to let the dealership deal with this one thanks you again
