1 - 6 of 6 Posts
Possibly the valve cover? Check the gasket to make sure it's not leaking.
Also there are five seals: the two cam shafts, the front balance shaft, the crank and the oil pump.
yeah, I was going to suggest the cam seals if it wasn't the vc gasket.
Discussion Starter #5
its not leaking bad. just alittle bit. if it was the cam seals would it leak alot. and i did remove the balancer shafts. and one elses idea. thanx
Now that I think about it, I think back when my oil pressure sending unit was leaking, it was slinging oil around the timing belt area. May want to check that general area (oil filter, oil press., etc.) for leaks as well.
1 - 6 of 6 Posts
