My seal there has been leaking pretty bad so I got a new one.
I just need to make sure this thing seals good. I will be coating it with oil on the outside. Should I coat the inside with oil too? And when sliding it in, should I slid it all the way back so it touches the front case?
Any advice appreciated, thanks.
My advice: keep the outside dry, but dab some oil on the inner seal lip. Also make sure the oil pump receiving end is clean, dry, and free of nicks or burrs.
Yes like said above just grease the inner lip.. I use lithum grease because it has a tiny bit of silicone in it to help seal.
