Did you break in the fresh clutch? Your symptoms point to that.AJ7734 said:
Did you break in the fresh clutch? Your symptoms point to that.AJ7734 said:I just recently had a low mileage motor put in and a new clutch setup. Everything runs good for the first 20-25 minutes I'm driving. Then....it just feels like something is slipping and no power gets to the wheels. All the gears engage perfect but you hit the gas and the engine just revs.But the only way you get any power is to rev it to 5 k in first and even then you only go 5 mph. Until it doesn't do anything.
The stock viscous coupling distributes power in a 50/50 ratio when there is a speed difference between the front and rear. Driving around with the transfer case off can nuke the VC pretty quick.95awd26 said:well my t case went out on me so i took it out and drove it as fwd and it had the same feeling as you are discribing i thought my cluch was out i took it to the dealership they put in a new t case (free of charge) and problm fixed i geuss the awd must work on like a 40 front to 60 back tracktion i dont know but it sounds like your t case to me (but im a newbe to dsm) so dont take my word for it jack both back wheels up put it in 1st gear and see if you can spin the wheel with your hand if it spins i would say yout tcase is out what do you guys thing im not 100% sure but thats what i would do if you dont want to take your t case off and check it hope this helps
gvr4dsmer said:No, up to mid 92' I believe is when they went to the 23 spline from 22
t-cases, the 22 have an aluminum "snout" while the 23's are cast iron. Some people speculate that the gvr4's were the 23 stock I however have yet to find one that way. Please correct me if I'm wrong, but when they started making the 7/4 in 92' is when I thought the 23 came in, maybe it was when they started the briefe run of the 6/4? I know someone will straiten things out...
