Check your clutch fork. Peel back the boot and have a look see. The stockers can become week over time. Ive seen a few forks break in half in my day. I picked up taboos fork a while back
gota0have0boost said:Check your clutch fork. Peel back the boot and have a look see. The stockers can become week over time. Ive seen a few forks break in half in my day. I picked up taboos fork a while back![]()
Here is what i did to check and see if the cables were broke.green92gsx said:Try to shift into 1st 2nd 3rd manualy at the trans itself. Double check and make sure you didn't break a shift cable.
It sounds like your stuck in 3rd.
dsmbuilder is right or possibly a broken roll pin that holds the 3-4 fork to the rail or maybe a whole lot of other things. My advise would be to take the tranny out and tear it down to see whats wrong. Trust me tranny work is not nearly as hard as you think it is, just like with an engine rebuild take your time and check everything 20 times before sealing it backup.dsmbuilder said:Sounds like a broken 3-4 shift fork.
Sent it out to tranny shop, I will let you know what happend later.pUtInExIm said:dsmbuilder is right or possibly a broken roll pin that holds the 3-4 fork to the rail or maybe a whole lot of other things. My advise would be to take the tranny out and tear it down to see whats wrong. Trust me tranny work is not nearly as hard as you think it is, just like with an engine rebuild take your time and check everything 20 times before sealing it backup.
thats exactly what happend to me, I got an update today.EclipZ said:same thing my tranny did when i broke the 3-4 shift fork. stuck in third gear, can start out in 3rd but it has to be in the nuetral position. if u put it in any other gear its stuck in 2 gears and wont move.. kinda like letting out on the clutch while pressing the brakes. the shift forks are weak aluminum, if they replace them at least get evo shift forks.
to tell you the truth, if you have the tools and parts i would go ahead and take it apart.. theres really nothing to it, but you might find more parts in there that need replacing like i did. if you put it all back together like it came apart, you shouldnt have any problems.jimib said:I beleivbe one of my AWDs is stuck in 3rd and its the 3/4 fork broken. It shifted great prior to, and I was wondering if anybody has had luck with fixing the fork and re assembling it, and everything working fine.
