Re: trying to figure out if my crank is seperating or if i have...crankw...DON'T SAY IT!!
It doesn't always "come off" The seperation is of the rubber dampning material between the inner and outer metal pulleys. The outer being the double belt grooves of the crank pulley, the inner being whats bolted to the timing gear underneath the cover. Sometimes it feels firm but the power of the car can "walk" it out. Or back in, ect. Give it a pull, and your belts are holding it tight. I'd take it off, and give it a good look. Sometimes it'll spin on itself and find a snug spot again making this a PITA. My 2g pulley I tapped, and it fell in pieces. My 1g, which I replaced it with... is 5 years older and is in good shape. (Go figure.)
Look at the timing cover behind it to see if there is chafing. Mine was dug apart and melty.
Some swirl marks indicate a bad pulley.
Once its off, tap the center bolt of the inner crank pulley with a hammer and a block of wood. Hold your breath, and have someone push the clutch. If it pushes out. You walked it. Also, if you tap it in, and it slides in a half inch...
Well you get the idea.
Be safe out there!
Be safe out there!
