Ok, I fixed it. I had to richen up the mid setting quite a bit.
These are my MAFT settings:
Base- "7" which is suppose to mean 700cc
Idle- "1" is 5% richer
Mid- "3" is 15% richer
WOT- "B" is 25% leaner
This looks very odd, considering that I was told that I have 450cc injectors.
On this setting at WOT I'm getting between 11.7-12.4 on the wideband.
When I make WOT 20% leaner instead of 25, I run around 11.1-11.6 at WOT. This is all the way through the rpm range.
Any idea's what injectors I have? Is it possible that the previous owner somehow increased the fuel pressure high enough to make it this rich on 450's? I don't have a aftermarket FPR, so I don't know what this guy did to the car.
My boost is set at around 19-20 psi.
