uh on, need help on water pump!
534 Views 5 Replies 4 Participants Last post by  Asmodeus
my water pump just started leaking. I need a how to on how to do it. Or someone fill me in on basics. Does the timing belt have to come off? how hard is it to do.
thanks
TJ
1 - 6 of 6 Posts
thanks
TJ
not a novice job. check vfaq.com and look under the timing belt pages
do i need a new timing belt. Tensioner, etc.
if the parts are good then you dont need new ones, they can be reused. have you ever had the timing belt replaced. what kind of milage is on your motor?
If you're taking it apart, replace the timing parts as well. It's a tough job, but can be done if you know your basics. Like mentioned before, go to the VFAQ and print off the instructions
If the timing belt has more than 10K miles I'd replace it. Make SURE you do the balance shaft belt tho. Pesky buggers have a tendancy to ruin perfectly good timing belts when they fail. Its a tricky process, but do-able.
1 - 6 of 6 Posts
