1 - 20 of 25 Posts
UPDATED: 90 awd shell and 91-94 turbo part out new prices and more parts added daily
INTER COOLER SET UP
FPR kit
boost gauge
SOLD!!!
I WILL SHIP EVERYTHING BUT THE CAR and the exhaust!!!
DO NOT ASK ME TO PART OUT BODY PANELS IT GOES WITH THE SHELL!!!
Body panels stay on the car you can get it with the shell
1990 With 91 wiring etc....eagle talon awd-black outside red inside rust free with 103k on it Clean title
Either the whole car goes or you buy the parts off it.
First come first serve.
THIS IS A FULL PART OUT AND WHOLE CAR FOR SALE AS IT SITS.
WHAT THE 90 TRANS LOOKS LIKE
MOTOR AND THE BLOCK
14B TURBO
Car is in martinsburg wv.
The interior is finished the interior shots are a few months old.
The car is a 90 awd eagle talon with 103k miles on it. no rust and lots of new parts.
Its a manual transmission with NO grinds. Was recently serviced by the last owner before it sat.
As the car sits now it is missing...
complete intercooler setup listed below head and a timing belt.
You can email me or call me 240-329-1165 to set up a time if you wanna look at the car...
THE TIMING BELT SKIPPED WHEN THE STARTER SPUN THE MOTOR OVER.
The motor is still good its just needs the head replaced or rebuilt. Since it bent valve when the starter spun the motor over.
Specs on this car:
Very nice paint only faded spot is the front bumper and roof.
******THIS CAR HAS BEEN COMPLETELY CONVERTED TO 91 ENGINE HARNESS NO 90 PARTS ARE ON THIS CAR!!!!!!!!!!!
-This car is black with a silver bottom.
-red interior.
-5 spd
-almost no rust, has very minor suface rust under the rear only. rest is clean.
-THIS TRANS IS MINT> its a 90 trans with no grind!
-New gas tank
-walboro 255 pump in tank.
-aeromotive fpr
-arp heabolts with no miles
-All the original body panel and all vins # match.
-awd
-Low miles 103k to be exact
-6 bolt motor, 3 bolt end with lsd
-rebuilt 6 bolt motor with less than 6000 miles on it(stock rebuild)
-tranny has no grinds
-rebuilt 14b with no miles
-new fidanza flywheel with new clutch (NOT EVEN BROKEN IN YET)
-ARP head bolts and new headgaskit.
- Complete all timing parts replaced.
-front mount intercooler with all piping, all new couplers and pipes with no miles on it
-crushed 1g bov ran with 25 psi still ran great.
-metal oil feedline
-newer radiator
-Walboro 255 fuel pump with complete re-wire.
-new viscous in the tranny
-new tires with only 6k on tires
-FPR from areomotive complete kit
-stock exhaust with cat delete and can welded on to it
-2.5 turbo back exhaust with cat, just needs the muffler welded on which i have.
-car has no ac and power steering but i have most of the stuff to put it in.
-every single dsm part or thing comes with car
- car has emissions removed
-ac stuff will be included with car
-the front lights are blacked out but i have stockers to replace them.
-intake mani, throttle body, bov. thremostat, etc has new gaskits on it never used.
-3in turbo throttle body elbow
-Car has a new awd gas tank with no rust and no broken bolts.
-car has stock turbo back exhaust as well as a 2.5 in turbo back exhaust.
-stainless steel metal clutch line new installed
I KNOW THERE IS MORE BUT I AM FORGETTING A FEW THINGS.
_____________________________________________
Stuff you need to know:
-I have every recept from the time i bought the car and all the parts that went into it, till now.
-Sorry i dont have a receipt for the motor, trans, turbo being rebuilt, the motor receipt never got it when the owner mailed me the receipts for the other stuff that i bought with the motor.
These are the things that need finished:
Head needs rebuilt or replaced.
Timing belt
The clutch needs broken in since its new.
Paint on the roof could use some love.
I want 1,450 for the whole complete car as it sits now plus 3 full boxes of parts for the car and all the parts i have for it now and all dsm parts i have.
Part out wise this is my prices.
-14b turbo with ported o2 and 2g mani no miles on the rebuild, mint condition
0 miles on new turbo and not even idling on the turbo
200 FIRM
It costs
60 for balance and 80 for the rebuild kit SO I AM FIRM ON THE PRICE ABOVE
-14b oil lines metal relocated oil filter ones both the feed and drain new never used
50 for both shipped
-Intercooler with 3 in throttle body elbow, and j pipe for 14b/16g etc... 2.5 in outlets complete for 1g turbo cars NEW everything: tbolt clamps, couplers, pipes etc...
intercooler is a lil bent on the bottom but does not leak and has a few minor bent fins.
whole kit goes together
WHOLE THING SOLD!!!!
-90 turbo awd trans WITH matching t-case MINT!!! no grinds not a junk trans. recently rebuilt with new viscous coupler inside.
trans and t-case
420
-90 t case mint nothing wrong with it, rebuilt about the same time as the trans.
just the t case
110
-7k on rebuilt motor. No shit take it apart on the spot i dont care i dont play it only has 7k on it. nothing to hide its mint.
Compression on motor before arps was
cyl 1,3,4
164
cyl 2 was 163
Thats 7k miles on it and stock parts
After the t belt skipped cranking it over
THIS TEST WAS DONE WHILE IT WAS COLD!!!
cyl 1 144
cyl 2,3,4 was 120 then leaked down
Valves job is needed guides may not be cracked
COMPLETE motor, with intake mani, and tb with new gaskits, cas, coil, injectors, arps
no valve cover, injectors
missing only the turbo, the timing belt, vc and injectors
motor is a 6 bolt
500
-Fidanza flywheel 6 bolt awd new never used with stock oem never used clutch.
230 shipped for both
Or
65 shipped clutch with new oem throw out bearing
180 shipped for the new fidanza flywheel
-90 awd shell with 103k on it Still has the rear diff, all the axles, drive shaft, engine harness, 255 walboro with rewire stays
NO ECU with the car.
complete interior..., radiator, all the body panels, new gas tank installed. etc.
comes with the stock exhaust
Turbo Engine harness is in the car!
Would just need a motor, turbo, ecu and trans basically.
450 firm
-AEROMOTIVE FPR
COMES complete with everything to bolt it onto a 1g even has new lines
SOLD
-2.5 turbo back exhaust needs muffler welded on but if you bring your dsm over i can weld it casue i have a welder
175 picked up
-Stock 450 cc turbo injectors
65 shipped
-Black valve cover in the above pics with all the hard ware/bolts to install
65 shipped
-2 non eprom turbo 91-94 ecus
Both 80 shipped each
-91-94 turbo mpfi
-90 turbo mpfi
-95 turbo mpfi
25 shipped each.
Lots of other parts for sale.
All is firm. Low ballers dont waste my time.
I also have a mig welder that welds anything a engine host with chain and a angle grinder for sale
Discussion Starter · #2 ·
Re: 90 awd full part out or buy the whole thing
fmic is not an ebay crap
looks to be an old bushur designed one
Comes with xtra couplers, t bolt clamps, the pipes are beaded and worked gret for me on my 50 trim at 25 psi
Comes with j pipe and elbow for the throttle body.
Also comes with crushed 1g bov
Discussion Starter · #3 ·
New stuff added
I want 2k for the whole complete car as it sits now plus 3 full boxes of parts for the car and all the parts i have for it now.
200
50 for both
330
90 turbo awd trans MINT!!! no grinds not a junk trans. recently rebuilt with new viscous coupler inside.
400
130
COMPLETE motor, with intake mani, valve cover, cas, coil, tb, injectors, arps, missing only the turbo and the timing belt.
motor is a 6 bolt
600
230 for both
90 awd shell with 103k on it Still has the rear diff, all the axles, drive shaft, engine harness, eprom ecu i believe BUT THE ECU IS THERE going with the car, fpr and 255 walboro goes with it. complete interior..., radiator, all the body panels, new gas tank installed. etc.
comes with the stock exhaust and a 2.5 in turbo back one
the fpr and 255 pump stays in the car
Would just need a motor, turbo and trans basically.
600
WILL NOT SHIP THE BIG STUFF UNLESS YOU PAY ME A GOOD BIT TO DO SO!!!!
How much for the hood?
Hey, I know you said you blacked out a pair of stock fogs for it, and you had another pair? What condition are the other ones athat aren't blacked out? Any pics? PM me with a price shipped.
Thanks John
So, what if I want to take the manifold with the turbo, stock smic and your bov? What would be my total shipped to 91911?
Discussion Starter · #12 ·
EDIT:
I cant pm you or email you so gimme a call...
240 329 1165
I HAVE NO SMIC AND THE CRUSHED BOV STAYS WITH THE INTER COOLER KIT!!!
NOT TO MENTION...
Almost everything has new never used gaskets on them.
Discussion Starter · #14 ·
Re: 90 awd full part out or buy the whole thing new prices and more parts added
The 90 shell stays complete.
In the next few days or in the next week i will have a complete 92 awd being parted out i just have to bring it from my other garage.
I mean anything and everything off that car!!!
I'm reeaallly tempted to come get that transmission from you.
My car needs it... just not sure if it's a logical purchase at the moment.
Discussion Starter · #16 ·
pm sent
But if its your DD then can you afford to be stuck when the trans craps out on you?
BTW the 6 bolt motor has new oil and filter on it with a new water pump
So if you can pick it up youll get fresh oil in it if i have to ship it i have to drain it all out.
If Anyone wants to i have the tools i can put the trans and or motor in your car to prove it
Re: UPDATED: 90 awd full part out or buy the whole thing new prices and more parts added
PM sent.
Does the car have aftermarket shocks and springs?
1 - 20 of 25 Posts
