1 - 20 of 32 Posts
This is my first log. Please don't flame or poke fun if there are any obvious things wrong as I'm trying to learn "the right way", not by just what I hear.
Here is a link to the file
This did not have any pulls in it, just casual driving. I did notice some flatlines in the o2 under vacuum. I haven't read where flat lining is normal, but rather it should be close to 0. I did notice down the log that the timing dropped rather low around 48.8 seconds into the log.
I know the SAFC II will cause the ECU to kick timing up a shitload to compensate for the air the SAFC II is pulling to compensate for the injectors.
I have a log I did with a couple pulls to post up shortly.
Here it is
I couldn't even do a full pull as the car started bucking. I don't know what's been going on with my car lately but it seems to run like shit now under any kind of high throttle.
My low throttle SAFCII settings are around -31%, High around -29%...Throttle low 30%, High 70%.
Discussion Starter · #3 · (Edited)
LOL...the log is in .CSV format. I was able to open it through Microsoft Excel. I have Microsoft Office 2007...I don't know if .CSV files are readable on 2003 or not.
Haha...you're welcome. I just googled "free file sharing" and that was the first one that came up. :)
I will post the log in text form; the log looks much cleaner and easier to read with excel. Maybe I can convert it to .xls so you can see it in regular Excel format.
First log in regular .xls (Excel) format
Pull log in regular .xls(Excel) format
Try again...updated.
I cant see that file either.
If you can, post something like this as well.. its time consuming but helpful for those of us without all that fancy nancy shit on our computers :D
RPM/02/Timing
1: 4000 0.85 22
2: 5224 0.91 24
3: 6356 0.95 19
4: 6312 0.95 18
5: 6564 0.95 16
6: 6796 0.95 17
7. 7148 0.95 -4 (Shifting into 3rd)
8: 6516 0.95 -3
9: 5096 0.95 6
10: 5236 0.95 7
11: 5348 0.95 7
12: 5428 0.95 8
13: 5540 0.95 9
14: 5620 0.95 10
15: 5712 0.95 10
16: 5816 0.95 10
17: 5880 0.95 11
18: 5960 0.95 11
19: 6036 0.95 12
20: 6092 0.95 11 (Had to let off due to car)
Discussion Starter · #5 · (Edited)
Ok...I'll work on it.
Try clicking the above two links in post 3 as I saved them as a readable file for excel 97-2003 after I realized I messed up the first time I posted the links.
I dont have excel and no way to view it.
You should be able to open any CSV (comma separated values) file in something as simple as Notepad. It's not as clean, but it works.
The logs aren't really of a straight and full pull to redline, the logs don't have a readout of the throttle position, and we don't know what kind of boost you're running or airflow your making, so it's a little tough to see what's going on, but from the RPM and O2 readout I'm guessing you went WOT about 4 sec in, let off a little in between, then came down around 15 sec.
If I'm reading my timing map correctly, you have more timing than you should at your RPM points throughout the log, because of your SAFC.
I'm not a pro on tuning so someone else with much more experience should chime in, but all together, you should do a 3rd gear pull, 2500-7000 RPM (if you feel comfortable at redline) pull at WOT clear through, with your throttle position logged, and report your boost.
You can download a free reader program but I don't know how much you really like HOT97... Is it really worth downloading? :p:D
Discussion Starter · #9 · (Edited)
OK non fancy smancies....
Time, Short Term Fuel Trim 1, RPM, Timing, O2 1 Bank 1, O2 Trim 1 Bank 1
00:00.43, -2.0, 3124.0, 34.0, 0.22, -3.12
00:00.86, -4.0, 3136.0, 34.0, 0.64, -3.12
00:01.27, -2.0, 3116.0, 34.0, 0.56, -3.12
00:01.71, -2.0, 3124.0, 33.0, 0.82, -1.56
00:02.14, -4.0, 3124.0, 29.0, 0.82, -3.12
00:02.57, -8.0, 3136.0, 27.0, 0.86, -6.25
00:03.00, -11.0, 3156.0, 27.0, 0.84, -10.16
00:03.43, -15.0, 3168.0, 28.0, 0.58, -14.06
00:03.86, -12.0, 3200.0, 29.0, 0.7, -10.94
00:04.28, -12.0, 3204.0, 29.0, 0.8, -10.94
00:04.72, -13.0, 3208.0, 30.0, 0.24, -14.84
00:05.13, -12.0, 3216.0, 30.0, 0.72, -11.72
00:05.57, -11.0, 3232.0, 32.0, 0.78, -10.16
00:06.00, -9.0, 3232.0, 32.0, 0.12, -10.94
00:06.42, -11.0, 3224.0, 32.0, 0.76, -9.37
00:06.84, -9.0, 3220.0, 32.0, 0.66, -9.37
00:07.28, -10.0, 3240.0, 32.0, 0.18, -10.94
00:07.69, -10.0, 3240.0, 30.0, 0.44, -10.94
00:08.13, -12.0, 3232.0, 30.0, 0.66, -10.94
00:08.56, -10.0, 3228.0, 30.0, 0.8, -9.37
00:08.98, -12.0, 3248.0, 30.0, 0.32, -13.28
00:09.40, -12.0, 3240.0, 29.0, 0.74, -10.94
00:09.85, -10.0, 3244.0, 30.0, 0.26, -12.5
00:10.27, -12.0, 3248.0, 30.0, 0.44, -13.28
00:10.69, -13.0, 3248.0, 30.0, 0.54, -12.5
00:11.13, -12.0, 3268.0, 32.0, 0.78, -10.94
00:11.56, -10.0, 3260.0, 32.0, 0.16, -10.94
00:11.97, -11.0, 3272.0, 32.0, 0.26, -11.72
00:12.40, -10.0, 3256.0, 32.0, 0.74, -9.37
00:12.85, -8.0, 3264.0, 29.0, 0.84, -6.25
00:13.27, -11.0, 3292.0, 26.0, 0.8, -10.16
00:13.71, -15.0, 3304.0, 19.0, 0.74, -14.06
00:14.13, -16.0, 3340.0, 11.0, 0.64, -16.41
00:14.56, -16.0, 3364.0, 7.0, 0.78, -16.41
00:14.98, -16.0, 3396.0, 11.0, 0.5, -16.41
00:15.40, -15.0, 3400.0, 15.0, 0.72, -14.06
00:15.84, -14.0, 3404.0, 16.0, 0.76, -12.5
00:16.27, -9.0, 3424.0, 19.0, 0.24, -10.94
00:16.70, -10.0, 3444.0, 32.0, 0.38, -11.72
00:17.12, -14.0, 3428.0, 33.0, 0.78, -12.5
00:17.55, -11.0, 3448.0, 33.0, 0.1, -11.72
00:17.98, -10.0, 3440.0, 33.0, 0.8, -8.59
00:18.42, -5.0, 3416.0, 33.0, 0.5, -6.25
00:18.84, -6.0, 3428.0, 34.0, 0.2, -7.81
00:19.27, -7.0, 3424.0, 34.0, 0.6, -6.25
00:19.70, -6.0, 3412.0, 34.0, 0.78, -5.47
00:20.13, -5.0, 3404.0, 34.0, 0.76, -3.91
00:20.56, -3.0, 3392.0, 34.0, 0.2, -4.69
00:20.98, -3.0, 3364.0, 34.0, 0.36, -3.91
00:21.42, -5.0, 3352.0, 34.0, 0.54, -4.69
00:21.85, -3.0, 3368.0, 34.0, 0.82, -2.34
00:22.28, -2.0, 3336.0, 34.0, 0.72, -1.56
00:22.70, -2.0, 3340.0, 34.0, 0.18, -3.12
00:23.13, -3.0, 3328.0, 34.0, 0.5, -3.12
00:23.56, -2.0, 3316.0, 34.0, 0.8, -1.56
00:23.98, -1.0, 3296.0, 34.0, 0.58, -1.56
00:24.43, -1.0, 3300.0, 34.0, 0.3, -1.56
00:24.86, 0.0, 3268.0, 34.0, 0.14, -1.56
00:25.29, -1.0, 3284.0, 34.0, 0.56, -0.78
00:25.71, -2.0, 3256.0, 34.0, 0.66, -0.78
00:26.14, 1.0, 3248.0, 34.0, 0.78, 1.56
00:26.56, 1.0, 3252.0, 34.0, 0.66, 0.78
00:27.00, -1.0, 3248.0, 34.0, 0.44, -2.34
00:27.43, -1.0, 3244.0, 34.0, 0.76, 0.0
00:27.85, -1.0, 3236.0, 34.0, 0.78, 0.78
00:28.28, 1.0, 3208.0, 34.0, 0.76, 0.78
00:28.70, -2.0, 3200.0, 34.0, 0.42, -2.34
00:29.12, -2.0, 3192.0, 34.0, 0.76, -0.78
00:29.56, -2.0, 3184.0, 34.0, 0.14, -3.12
00:30.00, -1.0, 3188.0, 34.0, 0.78, 0.0
00:30.43, -1.0, 3164.0, 34.0, 0.22, -1.56
00:30.85, -4.0, 3156.0, 33.0, 0.68, -3.12
00:31.28, -4.0, 3152.0, 33.0, 0.8, -3.12
00:31.71, -7.0, 3168.0, 32.0, 0.6, -6.25
00:32.13, -7.0, 3156.0, 32.0, 0.2, -8.59
00:32.56, -8.0, 3172.0, 32.0, 0.54, -7.81
00:33.00, -9.0, 3152.0, 32.0, 0.72, -7.81
00:33.43, -7.0, 3168.0, 32.0, 0.76, -6.25
00:33.84, -9.0, 3160.0, 32.0, 0.48, -9.37
00:34.27, -9.0, 3164.0, 32.0, 0.64, -7.81
00:34.70, -9.0, 3188.0, 32.0, 0.72, -7.81
00:35.13, -8.0, 3184.0, 32.0, 0.18, -8.59
00:35.56, -10.0, 3168.0, 32.0, 0.38, -10.16
00:35.99, -9.0, 3172.0, 32.0, 0.66, -8.59
00:36.41, -7.0, 3184.0, 32.0, 0.42, -8.59
00:36.84, -10.0, 3180.0, 33.0, 0.58, -9.37
00:37.27, -8.0, 3160.0, 33.0, 0.76, -7.03
00:37.70, -8.0, 3160.0, 33.0, 0.78, -7.03
00:38.13, -7.0, 3176.0, 33.0, 0.78, -6.25
00:38.56, -6.0, 3176.0, 33.0, 0.24, -7.03
00:38.97, -9.0, 3172.0, 33.0, 0.66, -7.81
00:39.40, -8.0, 3176.0, 33.0, 0.8, -7.03
00:39.84, -6.0, 3152.0, 33.0, 0.7, -5.47
00:40.27, -5.0, 3152.0, 33.0,0.18, -6.25
00:40.70, -2.0, 3160.0, 34.0, 0.12, -3.91
00:41.13, -3.0, 3140.0, 34.0, 0.56, -3.91
00:41.56, -3.0, 3132.0, 34.0, 0.74, -2.34
00:42.00, -2.0, 3152.0, 34.0, 0.76, -1.56
00:42.41, -2.0, 3128.0, 34.0, 0.78, -0.78
00:42.84, -2.0, 3128.0, 34.0, 0.82, -0.78
00:43.27, -3.0, 3124.0, 34.0, 0.5, -3.91
00:43.70, -2.0, 3128.0, 34.0, 0.62, -2.34
00:44.13, 0.0, 3116.0, 34.0, 0.78, 0.78
00:44.56, 3.0, 3084.0, 34.0, 0.3, 2.34
00:45.00, 2.0, 3076.0, 34.0, 0.48, 0.78
00:45.43, 2.0, 3068.0, 34.0, 0.74, 2.34
00:45.86, 4.0, 3056.0, 34.0, 0.76, 4.69
00:46.27, 4.0, 3044.0, 34.0, 0.2, 3.13
00:46.70, 3.0, 3032.0, 34.0, 0.6, 3.13
00:47.13, 2.0, 3044.0, 34.0, 0.7, 3.13
00:47.56, 2.0, 3032.0, 34.0, 0.78, 3.13
00:47.99, 3.0, 3012.0, 34.0, 0.74, 3.91
00:48.41, 2.0, 3008.0, 34.0, 0.6, 0.78
00:48.84, 2.0, 3004.0, 34.0, 0.44, 1.56
00:49.27, 2.0, 2988.0, 34.0, 0.8, 3.13
00:49.70, 2.0, 2996.0, 34.0, 0.22, 0.0
00:50.13, 1.0, 3000.0, 34.0, 0.74, 1.56
00:50.56, 2.0, 2992.0, 34.0, 0.18, 0.78
00:50.99, 0.0, 2988.0, 34.0, 0.68, 0.78
00:51.40, 2.0, 2964.0, 34.0, 0.82, 2.34
00:51.84, 1.0, 2956.0, 34.0, 0.24, -0.78
00:52.27, 0.0, 2972.0, 34.0, 0.72, 0.78
00:52.70, 0.0, 2956.0, 34.0, 0.82, 0.78
00:53.13, 0.0, 2964.0, 34.0, 0.8, 1.56
00:53.56, -2.0, 2968.0, 34.0, 0.6, -2.34
00:53.97, -2.0, 2972.0, 34.0, 0.8, -0.78
00:54.40, -2.0, 2968.0, 34.0, 0.8, -1.56
00:54.84, -2.0, 2968.0, 33.0, 0.78, -0.78
00:55.27, -5.0, 2952.0, 33.0, 0.66, -3.91
00:55.68, -4.0, 2956.0, 33.0, 0.74, -3.91
00:56.11, -8.0, 2960.0, 33.0, 0.7, -6.25
00:56.54, -6.0, 2968.0, 33.0, 0.8, -5.47
00:56.97, -6.0, 2972.0, 33.0, 0.28, -7.03
00:57.40, -6.0, 2976.0, 33.0, 0.42, -7.81
00:57.83, -8.0, 2976.0, 33.0, 0.66, -7.03
00:58.25, -7.0, 2976.0, 33.0, 0.8, -6.25
00:58.68, -6.0, 2976.0, 33.0, 0.78, -5.47
00:59.09, -5.0, 2984.0, 33.0, 0.7, -5.47
00:59.54, -5.0, 2988.0, 33.0, 0.4, -7.03
00:59.97, -8.0, 2992.0, 33.0, 0.56, -7.03
01:00.40, -6.0, 2980.0, 33.0, 0.78, -4.69
01:00.83, -5.0, 2976.0, 33.0, 0.8, -4.69
01:01.25, -5.0, 2988.0, 33.0, 0.78, -4.69
01:01.68, -5.0, 2984.0, 33.0, 0.24, -6.25
01:02.11, -5.0, 3004.0, 33.0, 0.54, -5.47
01:02.54, -7.0, 3004.0, 33.0, 0.66, -6.25
01:02.97, -5.0, 3000.0, 33.0, 0.62, -6.25
01:03.40, -5.0, 3016.0, 32.0, 0.6, -5.47
01:03.81, -9.0, 3032.0, 32.0, 0.62, -7.81
01:04.25, -9.0, 3020.0, 32.0, 0.66, -7.81
01:04.68, -8.0, 3044.0, 32.0, 0.8, -7.03
01:05.11, -7.0, 3044.0, 32.0, 0.18, -8.59
01:05.54, -5.0, 3056.0, 32.0, 0.56, -6.25
01:05.97, -9.0, 3048.0, 32.0, 0.68, -8.59
01:06.40, -9.0, 3072.0, 32.0, 0.74, -7.81
01:06.83, -8.0, 3076.0, 32.0, 0.78, -7.03
01:07.26, -7.0, 3084.0, 32.0, 0.5, -7.81
01:07.69, -7.0, 3084.0, 33.0, 0.24, -8.59
01:08.12, -9.0, 3084.0, 32.0, 0.42, -9.37
01:08.54, -9.0, 3096.0, 32.0, 0.56, -9.37
01:08.97, -9.0, 3104.0, 33.0, 0.66, -8.59
01:09.40, -9.0, 3112.0, 33.0, 0.76, -8.59
01:09.83, -7.0, 3124.0, 33.0, 0.44, -7.81
01:10.26, -8.0, 3120.0, 33.0, 0.46, -9.37
01:10.69, -9.0, 3116.0, 33.0, 0.64, -8.59
01:11.12, -9.0, 3132.0, 33.0, 0.78, -7.81
01:11.54, -8.0, 3136.0, 33.0, 0.54, -8.59
01:11.97, -8.0, 3128.0, 33.0, 0.28, -9.37
01:12.38, -9.0, 3148.0, 33.0, 0.6, -9.37
01:12.81, -8.0, 3136.0, 33.0, 0.78, -7.03
01:13.25, -8.0, 3152.0, 33.0, 0.14, -9.37
01:13.68, -9.0, 3140.0, 33.0, 0.6, -8.59
01:14.11, -5.0, 3144.0, 33.0, 0.78, -4.69
01:14.55, -8.0, 3168.0, 33.0, 0.48, -8.59
01:14.98, -9.0, 3172.0, 33.0, 0.62, -7.81
01:15.40, -6.0, 3156.0, 33.0, 0.74, -5.47
01:15.83, -4.0, 3152.0, 33.0, 0.16, -5.47
01:16.26, -5.0, 3168.0, 33.0, 0.42, -6.25
01:16.68, -5.0, 3168.0, 33.0, 0.72, -4.69
01:17.11, -4.0, 3168.0, 33.0, 0.7, -3.91
01:17.54, -4.0, 3152.0, 33.0, 0.14, -5.47
01:17.97, -5.0, 3160.0, 33.0, 0.66, -4.69
01:18.38, -5.0, 3160.0, 33.0, 0.64, -4.69
01:18.81, -4.0, 3144.0, 33.0, 0.8, -2.34
01:19.23, -3.0, 3144.0, 33.0, 0.18, -4.69
01:19.66, -4.0, 3156.0, 33.0, 0.54, -4.69
01:20.11, -4.0, 3136.0, 33.0, 0.5, -4.69
01:20.54, -4.0, 3136.0, 33.0, 0.56, -4.69
01:20.97, -5.0, 3160.0, 34.0, 0.66, -3.12
01:21.40, -4.0, 3144.0, 34.0, 0.6, -3.91
01:21.83, -3.0, 3136.0, 34.0, 0.16, -4.69
01:22.26, -5.0, 3116.0, 34.0, 0.78, -3.91
01:22.69, -2.0, 3108.0, 34.0, 0.56, -3.91
01:23.12, -2.0, 3088.0, 34.0, 0.22, -3.12
01:23.55, -1.0, 3096.0, 34.0, 0.64, -1.56
01:23.97, 1.0, 3076.0, 34.0, 0.76, 1.56
01:24.41, 3.0, 3064.0, 34.0, 0.74, 3.91
01:24.83, 5.0, 3044.0, 34.0, 0.22, 3.91
01:25.26, 5.0, 3032.0, 34.0, 0.24, 3.91
01:25.69, 4.0, 3040.0, 34.0, 0.66, 3.91
01:26.12, 4.0, 3028.0, 34.0, 0.76, 4.69
01:26.54, 1.0, 3024.0, 34.0, 0.66, 1.56
01:26.97, 0.0, 3000.0, 34.0, 0.5,- 0.78
01:27.38, -2.0, 3000.0, 33.0, 0.76, -1.56
01:27.81, -2.0, 3000.0, 33.0, 0.8, -1.56
01:28.25, -4.0, 3008.0, 33.0, 0.54 ,-4.69
01:28.68, -5.0, 3004.0, 33.0, 0.7, -3.91
01:29.09, -4.0, 3020.0, 32.0, 0.7, -3.91
01:29.52, -7.0, 3016.0, 32.0, 0.62, -6.25
01:29.95, -6.0, 3020.0, 32.0, 0.8, -5.47
01:30.37, -8.0, 3040.0, 32.0, 0.44 ,-9.37
01:30.80, -9.0, 3028.0, 32.0, 0.64, -8.59
01:31.23, -8.0, 3044.0, 32.0, 0.78, -7.03
01:31.66, -9.0, 3056.0, 32.0, 0.78, -7.03
01:32.09, -8.0, 3044.0, 32.0, 0.6, -7.81
01:32.52, -7.0, 3072.0, 32.0, 0.74, -6.25
01:32.94, -9.0, 3068.0, 32.0, 0.5, -9.37
01:33.37, -9.0, 3076.0, 32.0, 0.74, -7.81
01:33.80, -8.0, 3064.0 ,32.0, 0.7, -7.81
01:34.23, -9.0, 3068.0, 32.0, 0.34, -10.16
01:34.66, -9.0, 3088.0, 32.0, 0.68, -8.59
01:35.09, -9.0, 3076.0, 32.0, 0.74, -7.81
01:35.52, -8.0, 3092.0, 32.0, 0.18, -8.59
01:35.94, -9.0, 3092.0, 33.0, 0.3, -9.37
01:36.37, -9.0, 3084.0, 33.0, 0.54, -9.37
01:36.80, -9.0, 3092.0, 33.0, 0.66, -9.37
01:37.23, -8.0, 3096.0, 33.0, 0.78, -6.25
01:37.66, -5.0, 3096.0, 33.0, 0.72, -4.69
01:38.08, -5.0, 3108.0, 33.0, 0.76, -4.69
01:38.51, -4.0, 3112.0, 33.0, 0.14, -5.47
01:38.94, -3.0, 3088.0, 34.0, 0.5, -4.69
01:39.37, -3.0, 3096.0, 34.0, 0.74, -2.34
01:39.80, -2.0, 3104.0, 34.0, 0.5, -3.12
01:40.23, -2.0, 3108.0, 34.0, 0.36, -3.12
01:40.66, -5.0, 3096.0, 34.0, 0.74, -3.91
01:41.08, -2.0, 3080.0, 34.0, 0.3, -3.91
01:41.51, -3.0, 3088.0, 34.0, 0.4, -4.69
01:41.94, -5.0, 3080.0, 34.0, 0.72, -3.12
01:42.36, -2.0, 3076.0, 34.0, 0.76, -2.34
01:42.80, -1.0, 3052.0, 34.0, 0.64, -1.56
01:43.23, -2.0, 3052.0, 34.0, 0.4, -3.12
01:43.66, -2.0, 3044.0, 34.0, 0.72, -1.56
01:44.08, -1.0, 3036.0, 34.0, 0.6, -1.56
01:44.51, 0.0, 3040.0, 34.0, 0.58, 0.0
01:44.94, -2.0, 3032.0, 34.0, 0.64, -2.34
01:45.37, 0.0, 3020.0, 34.0, 0.74, 0.78
01:45.79, 1.0, 3004.0, 34.0, 0.48, 0.78
01:46.22, 2.0, 3008.0, 34.0, 0.24, 0.0
01:46.65, 0.0, 2992.0, 34.0, 0.64, 0.0
01:47.08, 2.0, 2992.0, 34.0, 0.78, 2.34
01:47.51, 2.0, 2968.0, 34.0, 0.72, 2.34
01:47.93, 2.0, 2976.0, 34.0, 0.38, 0.0
01:48.36, 1.0, 2948.0, 34.0, 0.68, 0.78
01:48.77, 1.0, 2956.0, 34.0, 0.76, 1.56
01:49.20, 2.0, 2936.0, 34.0, 0.8, 3.13
01:49.63, 2.0, 2944.0, 34.0, 0.34, 0.78
01:50.06, -5.0, 2932.0, 34.0, 0.76, -4.69
01:50.65, 0.0, 2924.0, 23.0, 0.06, 0.0
01:51.08, 0.0, 2860.0, 23.0, 0.0, 0.0
01:51.51, 0.0, 2840.0, 23.0, 0.0, 0.0
01:51.94, 0.0, 2836.0, 23.0, 0.0, 0.0
01:52.37, 0.0, 2812.0, 23.0, 0.0, 0.0
01:52.80, 0.0, 2788.0, 23.0, 0.0, 0.0
No pulls...just normal driving.
You guys love me long time, riiight? :eek:
Dustin, the best way I found to make it work is to bring up the number in PLViewer. Than just do a "Print Screen" and open it up in paint. Then crop it and save it as a .jpeg Then host it on Imageshack.us and paste it on here. Works like a charm.
Take a peek at my old thread to see how it looks when you do that.
http://www.dsmtalk.com/forums/showthread.php?t=195770
3300-3500could use a LITTLE more fuel.
Theres some extreme timing there I can definetly tell your using 660cc+ injectors and a piggy back. Looks good though.
I still suspect knock due to the high timing. Maybe the ecu didnt catch it?
Discussion Starter · #16 ·
Stock FPR.
I have a 190 wally; I could be overrunning it but I'm not sure how to test that.
I'm kinda lost. If you were to look at my o2 values on a graph they go up and down like a fucking zig-zag and don't stabilize very much.
HOT97ECLIPSEGSX said:
Stock FPR.
Thats what theyre made to do, theyre just narrowband o2 sensors.
Discussion Starter · #18 · (Edited)
Any ideas? Let me post my Pull log...but it won't be as pretty as the other one. Looks like I need to take out a trim and add throttle percentage.
Time,Short Term Fuel Trim 1,RPM,Timing,O2 1 Bank 1,O2 Trim 1 Bank 1
00:00.43,5.0,2720.0,34.0,0.16,3.91
00:00.86,3.0,2724.0,34.0,0.56,3.13
00:01.27,4.0,2748.0,34.0,0.78,4.69
00:01.72,-5.0,2752.0,34.0,0.16,3.91
00:02.15,0.0,2636.0,34.0,0.14,0.0
00:02.57,0.0,2112.0,19.0,0.02,-4.69
00:03.00,4.0,1760.0,19.0,0.06,2.34
00:03.43,9.0,3180.0,15.0,0.46,7.81
00:03.86,0.0,4604.0,35.0,0.04,0.0
00:04.28,0.0,4496.0,35.0,0.18,0.0
00:04.72,0.0,4620.0,22.0,0.92,0.0
00:05.15,0.0,4776.0,16.0,0.94,0.0
00:05.57,0.0,4948.0,16.0,0.94,0.0
00:06.00,0.0,5104.0,17.0,0.94,0.0
00:06.42,0.0,5244.0,19.0,0.88,0.0
00:06.86,0.0,5360.0,20.0,0.92,0.0
00:07.30,-5.0,5508.0,35.0,0.82,-1.56
00:07.73,0.0,4964.0,34.0,0.9,0.0
00:08.14,0.0,4140.0,22.0,0.94,0.0
00:08.57,0.0,4252.0,19.0,0.96,0.0
00:09.00,0.0,4348.0,19.0,0.96,0.0
00:09.43,0.0,4464.0,19.0,0.98,0.0
00:09.85,0.0,4500.0,19.0,0.98,0.0
00:10.27,0.0,4608.0,19.0,0.96,0.0
00:10.71,-5.0,4720.0,35.0,0.74,-4.69
00:11.14,0.0,4152.0,29.0,0.88,0.0
00:11.57,0.0,3752.0,24.0,0.94,0.0
00:12.00,0.0,3796.0,22.0,0.94,0.0
00:12.43,0.0,3856.0,22.0,0.94,0.0
00:12.85,0.0,3908.0,21.0,0.94,0.0
00:13.27,0.0,3936.0,17.0,0.96,0.0
00:13.69,0.0,4020.0,17.0,0.96,0.0
00:14.13,0.0,4060.0,19.0,0.96,0.0
00:14.56,0.0,4128.0,20.0,0.96,0.0
00:15.00,0.0,4152.0,21.0,0.96,0.0
00:15.43,-5.0,4168.0,34.0,0.8,-4.69
00:15.85,0.0,4196.0,34.0,0.74,-4.69
00:16.29,0.0,4144.0,23.0,0.24,0.0
00:16.71,0.0,4144.0,23.0,0.0,0.0
00:17.13,5.0,4100.0,34.0,0.06,3.13
00:17.56,0.0,4140.0,29.0,0.9,0.0
00:18.00,0.0,4152.0,26.0,0.92,0.0
00:18.42,-5.0,4164.0,26.0,0.92,-0.78
00:18.85,-5.0,3984.0,34.0,0.86,-4.69
00:19.27,0.0,3420.0,23.0,0.8,0.0
00:19.70,0.0,2792.0,23.0,0.02,0.0
00:20.13,0.0,2180.0,20.0,0.0,0.0
00:20.56,0.0,1580.0,11.0,0.0,0.0
00:21.00,1.0,1080.0,15.0,0.02,0.78
00:21.42,2.0,1024.0,15.0,0.04,0.78
00:21.85,2.0,952.0,13.0,0.04,1.56
00:22.28,2.0,916.0,9.0,0.06,2.34
00:22.71,3.0,900.0,8.0,0.06,2.34
00:23.13,5.0,896.0,15.0,0.06,3.91
00:23.56,5.0,2488.0,8.0,0.22,3.91
00:24.00,0.0,4584.0,35.0,0.04,0.0
00:24.43,0.0,4980.0,35.0,0.04,0.0
00:24.85,0.0,4980.0,32.0,0.9,0.0
00:25.28,0.0,5016.0,20.0,0.94,0.0
00:25.70,0.0,5092.0,16.0,0.96,0.0
00:26.12,0.0,5348.0,35.0,0.9,-4.69
00:26.55,0.0,4428.0,26.0,0.92,0.0
00:26.97,0.0,4148.0,20.0,0.96,0.0
00:27.40,0.0,4180.0,16.0,0.98,0.0
00:27.82,0.0,4232.0,15.0,0.98,0.0
00:28.26,0.0,4312.0,16.0,0.98,0.0
00:28.69,0.0,4336.0,17.0,0.98,0.0
00:29.12,-5.0,4292.0,34.0,0.78,-4.69
00:29.55,-5.0,3780.0,34.0,0.8,-4.69
00:29.97,0.0,3208.0,23.0,0.3,0.0
00:30.40,0.0,2572.0,22.0,0.02,0.0
00:30.84,0.0,1956.0,16.0,0.0,0.0
00:31.26,1.0,1388.0,7.0,0.0,0.0
00:31.69,1.0,1092.0,19.0,0.02,0.78
00:32.11,2.0,1012.0,14.0,0.06,1.56
00:32.54,2.0,952.0,11.0,0.06,1.56
00:32.97,2.0,916.0,10.0,0.06,2.34
00:33.40,3.0,884.0,10.0,0.06,3.13
00:33.83,4.0,880.0,8.0,0.12,3.91
00:34.27,4.0,872.0,9.0,0.66,3.91
00:34.70,3.0,884.0,8.0,0.64,3.13
I'll post with screenshots from now on to make life easier for everyone, including me. :)
Discussion Starter · #20 ·
Not only does that look like shit, but my timing is going \/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/...kinda similar to what my o2 is doing.
Ok so to take care of this do I need to add % on the SAFCII to make up for that? Won't that make me run rich?
Bah...:eek:
1 - 20 of 32 Posts
