I recently had the manual transmission fluid changed out to synthetic, and now I have a problem. I guess I should say first that it was warm weather when I had this done, and I got the car back when the weather had turned cold. The problem is that it sometimes doesn't want to go completly into second gear, and if you are shifting relatively fast it will sometimes briefly rake as it goes in(more of a quick chirp). I guess as I try to diagnose I want to start with the easiest first, so would changing back to standard gear oil possibly help?
