I. Keep blowing 15 amp fuse on the stop light switch. Replaced the brake Showbox jiofi.local.html tplinklogin switch but I have 2 wires one black other green on the audio line where do they go View attachment 34023
Having too many devices plugged into a circuit is the most common cause of fuses blowing. ... Another potential cause of fuses blowing is a short circuit. When a hot wire touches either the grounding pathway or a neutral wire, it results in the circuit shorting out.
