Yes, this is true. Not all, but most changers do have a manual release that is accessed that way. I use a metal back bracket, but a thin ruler will work fine. Insert it below the catridge, and in the middle. Carefully work the ruler in and out, and with a little luck; the cartidge will pop out.whiteGSX said:It means a cd is jammed inside the changer. Take a ruler and shove it into the changer, there should be a release mechanism that will allow the magazine to pop out manually. Then turn on the changer without the magazine to "reset" it, and then put in the magazine.
hope this helps.
