When will i require fuel pump upgrade.
1512 Views 6 Replies 6 Participants Last post by  elewie
Hello, I am about to buy an Eagle Talon TSI 2.0L AWD Turbo and I was wondering, would a stock fuel pump cause any problems if the guy has a few upgrades to add quite a bit of power because I want to know if i should buy a Walbro immediately. I dont want any fuel cut problems or anything like that.
1 - 7 of 7 Posts
If you upgrade your injectors bigger than 550 and in some cases 550 will need a fuel pump upgrade. Depends a lot on how much you are boosting with what kind of turbo. If you get fuel cut before 4700 rpm you probably do need some fuel upgrades.
i am at 17psi and i just got a fuel pump, i was always told you dont want to go over 12psi with a stock fuel pump
your stock injectors max out before your fuel pump does..i have 450s and run 18 psi on the 14b.. but its re-wired..
im actually running stock boost but i have upgraded the injectors and fuel pump as well. i think its a good route to go because your dont want fuel cut. but to each his own :cool:
Ugh....lets think before we post guys.
Whether or not you need a fuel pump is not dependant on the size of your injectors. If you have maxxed out a set of 550s you have probably exceeded the flow limit of the stock pump by a margin.
Fuel cut has nothing to do with your fuel pump. It is based on an airflow level.
It is pretty tough to outflow a stock pump, especially rewired, with a t25. 16psi is at the efficiency limit of the turbo and your fuel pump will still be keeping up at that level.
1 - 7 of 7 Posts
