my clutch is starting to slip.. its real easy to push in so im PRAYING that it just needs to be bled, so, where do you bleed it from? where is the little bolt/nob/fitting whatever you take off before you pump it to get the air out?
also.. if indeed i do need a new clutch.. how hard is it to install and whats a good one to get? I dont plane on going super heavy on mods and my car is FWD.. so I dont need anything TOO extreme
u bleed the clutch under the car 'fun to get at' if u crawl right under, semi in middle, more towards passanger side ur gonna see the bleeder valve, look for about 2mins and ull find it, easy to find, kinda a bitch to get at crawlin under such a low car=p
what clutch u get depends on what u want ur car to do, what u plan on doin.
well lets see, ive got a full 3" exhaust now, and im buying a T-28 from AGP around X-mas.. and thats about it.. ill go to the track every now and then but by no means is this a race car..
ok i dont even have the BEGINNINGS of an idea of what im looking for.. what does the bleeder look like? I cant believe there is nothing on VFAQ about this or some pics SOMEHERE.
well I just ordered an exedy clutch, cost $160 shipped 2nd day air.. from what ive read they are pretty good clutches, about 20-30% stronger than stock and last pretty good.. hope the install isnt a total bitch and a half
you're going to try to isntall a clutch yourself when u didnt even know how to bleed it. not trying to be rude or anything...it just might take you a while. good luck
