Mine does the same thing right around 2k-2500k, i found out that it was my Manual boost controller(*MBC*).
Im with him or did i also miss something?maui6651 said:Blow off valve? It seems too obvious, but I have to ask.
Ryan
Sleepingtsi95 said:ok guys, check this out when im driving and i let off the gas, there is a slight whistle that goes for about one sec, i thought it was just me but i had alot of friends tell me they heard it. -the noise almost sounds like bad breaks but waaaay softer. its obviuosly not the brakes, and i thought it was the clutch but its definately making the noise when i let off the gas....what is this NOISE!! i it good, bad or does it matter at all?????- sorry its driving me crazy
Yunebug said:Yes, that's what I found as well. I replaced the 1G with a HKS SSQV with recirculation kit, and the whistle went away! YAY!
...then another problem. I've done some research, and I found that HKS SSQV flutters... whistling is gone, but not it flutters. (sigh).
SO I've gone back to the 1G BOV. Anybody want HKS SSQV BOV flanged for 1G?
thescamp said:Good info on the injector orings... A good way to test for this (and other leaks) is by shooting the areas of suspision with starting fluid - your idle will bump up a lil if there is a leak.
