1 - 7 of 7 Posts
Honorary Moderator
So, okay, I hooked up my *new* Auto Meter A/F ratio gauge to this wire under my dashboard (right where DSM.org said it would be) and the gauge seemed to work fine. The next time I start my car, one of the LEDs is not working. Strange. My car sits the next day, I have no life. The next day (today), I drive to work, the gauge is not even lighting up (yes, I have a good ground and power supply) Then, to make matters worse, (murphy maybe?) my check engine light comes on. (coincidence? I think not.) I disconnect the wire, drive it again, light goes off, problem solved. EXCEPT, now I have the meter, but can't use it.
Bottom line: Is the meter bad, or is my car possessed? Any help is appreciated...
John
I would hook up another air fuel gauge in its place. It is possible you got a bad gauge. Also, you should use a scan tool to find out what that check engine light is from next time. Could shed some light on the problem.
-Brian
Project GSX
http://www.projectgsx.com/
Don't really know if the 2 things are related or not. But it might be a coincedence. Try another guage. Maybe the wire that you ae hooking it up to has a short somewhere in the line. And it only affects it when you are trying to read the o2 voltage.
You are supposed to install an inline fuse (5amp) in the power wire of the Auto Meter A/F gauge. If you didn't, you may have shorted out your gauge - and i agree with the other two replies, you proably need a new gauge. PUT THAT FUSE IN - it will save you $50!
Honorary Moderator
Discussion Starter · #5 ·
Yup, gonna replace the gauge. Just it's a pain to pull that thing out and put a new one in. Also, I did use a fuse, always do. You all just confirmed my suspician that the gauge is shot, good thing the Summit Racing store is right around the corner...
I don't know if this has anything to do with your problem, but is it possible that your connection to the O2 sensor was bad? I don't know how you spliced the connection but sometimes when using the crimp connectors it is possible to frey the wires and cause a short. Maybe you should check to make sure that the o2 wire leading to the computer is not cut or freyed in any way.
Brian P.
Best time: won't even try until I get a decent turbo
Honorary Moderator
Discussion Starter · #7 ·
Well, I found the problem. The wire going to my o2 sensor was crushed when I put the screw back in for the lower part of the dashboard. The screw pierced the rubber and was shorting the wire to ground. I found this out when I took out the old gauge to exchange it for a new one. New one works great, problems olsved. Thanks for the help!
John Lewis
1991 Eclipse GS Turbo
1 - 7 of 7 Posts
