Ok, I found a 14b map:
Now if you look at that and consider that ~300hp (260-270whp) is made around ~22psi, then you see that's @72% efficiency (380cfm), and there is more airflow to be had on the map.
Conceivably with more breathing the 14b can make over 300hp (fly) no problem, as has been proven by Leon's accomplishment.
I am led to believe that the stock cams are a restriction to what the 14b can flow on paper. That and/or that 2g pistons (or any bump in compression) would provide some added VE/airflow. Both of which Leon benefitted from (I'm pretty sure he had a built motor of some sort? :dunno: )
Man I want 2g pistons...lol...
But this is all bench racing since things never work out in real life like they do on paper...
-aaron
