After i changed my belts my crank puller makes a like clucking sound while its turns , would too much tention do this ? I have a sound file on my computer of it is there a way to upload a sounds file ?
NEPhillyGuy said:harmonic balancer ?? can you explain more about this /where is it ? so i can take a better idea of it ?
Nevermind, I just saw that the other guy has a 99 GSX, so it's not you. Strange that you're both from the Philly area and have a similar sounding problem.91TSiGuy said:Just curious, but are you the same guy on Tuners who posted that he thought his car crankwalked because the crank pulley was hitting the frame of the car even after replacing the alternator belt that broke?
Good god, not to beat a dead horse but check the damn crank pulley yourself and stop being such a lazy bastard. Loosen your alternator with ONE bolt, you can loosen your ac tensioner with 2 bolts, lay on the ground and grab the pulley and try to spin it. If thats too difficult for you buy a different car because lord knows you wont be able to handle any of the other fun jobs...NEPhillyGuy said:its goes , clicky tee klaa caaateeeee chikchik boommm waaa waaaa chik chik . crank pulley ?![]()
