Before you ask, yes, I have checked all boost leaks, replaced the silicone lines that had rotted away, but my T25 seems to be running really high boost.
I put the greddy BOV on, I tried running the line from between the turbo wastegate and the actuator that leads up to the second nipple, and I was hitting upwars of 2.0 bar! (momentarily)) so I tossed that out and put the straight line back in (Someone should update the VFAQ that you should run a Boost Controller before you do that).
Now it's running still very high. I've hit 1.5 (around 21-22 psi) bar a few times in second and then it drops, but when I'm in third, it stays at about 1.2-1.3 (17 psi!?!?) bar which seems VERY high. I didn't run the car that long in third to see if it dropped a lot or at all, so I'm hoping this is okay. I'm still runnign the bone stock fuel system, and would rather not have my one method of transportation blow some pistons.
Few facts: I am running an N1 Downpipe (I know it was supposed to spike, but this much? And for this long?), 94 Octane, Venting back into the intake. My exhaust temps are normal and are not going over their regular tempurature. The little wastegate solinoid restrictor is long gone due to a previous owner.
I'd appreciate it if this is considered normal, or if I've screwed up somehow. It seems just to be boosting too high and going too fast for a simple Upper intercooler pipe/BOV upgrade.... or are 2nd gen BOV's that much of a giant plastic piece of shit?
