(2g TSi AWD A/T - 16g, ported, 34mm wg, all hard IC piping, intake, type-s vented(yea yea), o2 dump, 2.5" dp to full 3" apexi n1, mbc, safc)
Ok, I'm at a loss already
Here's what is happening:
- Wants to die when first starting up in the morning, unless I raise the LowThrottle 1k setting to +10. I can lower it back to 0 when its been running for a minute or 2.
- Doesn't really want to go when boosting, loud spoolup, only hits a max of 10psi. It runs just fine when it's in vac.
- Did a boost leak test with a huge compressor, the boost gauge doesn't even move, and I can't hear *anything* leaking, not even from the mbc bleeder hole. No air coming out of the exhaust either. I know the tester works, because it found a TB leak on my brothers car just minutes afterward.
- The wastegate arm did not move on my car when doing leak test, opened on my brothers just fine. I can pull it open with my hand, but it takes alot of strength.
- Did a compression test, 190-185-180-185
- New spark plugs gapped at .28, then tried .32.
[misc.]
- 1 manifold stud snapped off in head, top right. Been like that for months.
- o2/dp gasket probably shot, i can feel exhaust putt-putt out of it while idling, but that also has been like that for quite a while.
- Keep getting P1500 code for Alternator Terminal Circuit... but I think it's because the ghetto rigged o2 dump tube (exhaust flex pipe clamped on for extension) is very close to alternator, and almost melted the wiring until i gobbed some copper rtv on it and it's held up fine. It charges fine, never dims, etc.
[Things left to look at]
- pressurize wg nipple directly to see if wg arm opens.
- check ecu?
ANY suggestions?
[misc.]
- check ecu?
ANY suggestions?
