i just did a search on this because i havent been able to get my car to run right ever since i got it back from the shop and found out a few things that i need a little explaining after i searched. i believe the shop that did my6 bolt swap to my 2g head (99 gsx) put a 90 cas in the car. now is this right or do you need a 93-94 cas as i read while searching around??? the car is misfiring like crazy and the timing is way off. if that is true, how do i fix this problem. i can tune with greddy emanage ultimate and log everything so i know what is going on. that is how i know the timing is way off. but i was reading somewhere about misfiring and the timing being off, and i keep pulling a cell of injector circuit-cylinder 1. thanks for the help.
