sandcobra164 said:
I've had this problem before, Code 15 is Idle Speed Control Motor Position Sensor. When that fails, you're car will have a rev limit of about 2000 rpm while the check engine light is on with that code. It's a real pain in the ass but to get ya by, just disconnect the five wire connector on the idle speed control motor, adjust the base idle to 900 rpm and you should be good to go. That wire is just behind the the rubber intake pipe where it connects to the throttle body. You should be able to find it without a problem. You can't buy that sensor seperately but if you find an Idle Speed Control motor in a junkyard it'll have what you need and you shouldn't have to spend too much. Brand new, they're about 220 bucks. When you get a good one, be sure to clear the computer or it'll still act a little crazy. Good Luck!!!
As always, Excellent advice from someone who KNOWS.
Rock on sandcobra164... :burnout:
Now MY opinion as for the 'code 15' stuff...
The 'code 15' is a retained code and the computer needs to be reset to delete it.
I have had this code for a few years now (no damn way I am spending that much $$$ to fix a mildly crappy idle that can be easily adjusted by putting my foot on the gas a little bit when it tries to drop some) and my car has suffered NO ill effects. (stop laughing, The price of a new ISC will buy a BUNCH of beer
This code will NOT kill your computer, has NOTHING to do with the MAF (swapping will not help) on our cars, and is NOT going to go away with a new computer...
Even with the code 'occasionally' popping up for me, I still get at least 540 to 550 miles per tank. Affecting gas mileage is NOT a problem.
I have experienced no issues at all with my rev limit stopping short because of the ISC. This likely depends on the position that the ISC pintle was in when it failed. If you are having problems with the rev limit being low, you may want to try unplugging it as suggested by sandcobra164. I have not had this problem and have not had to unplug anything on my car FWIW.
If the idle problems are bothering you that bad, Then you may want to contact
www.crebotech.com. They will rebuild the ISC that you have for CHEAP and it will work with no 'gambling' on a junkyard part. (They will also buy your old, junk ISC motors from you if you need to find them a home)
I believe they warranty their part as well... (Problem solved, but you will be out some beer money...
Hope this helped you some Clavette, I was trying.
You can leave the test light for your computer hooked up all the time and watch this code come and go as you are driving along. It is very easy to mount the light in your console and be able to monitor for codes all the time.
This WILL come in handy and only requires a little wire and an LED.
Best of luck Clavette
