1 - 20 of 22 Posts
u4ikstilz
So I've pulled out all the sound deadening under the rear seats,
and I'm wondering if there's any more?
A few lbs total, but it helps.
And I saw a plug under the driver's seat, wth is this?
I don't mind, I need a project to cure my boredumb.
I wonder if the last owner took it out already?
I looked under the carpet before and didn't see anything.
But I just pulled the corner, like near the door/backseat.
Maybe I need to pull the seats and console out to get the carpet out.
If it's anything like under the rearseats, they pulled out by hand, it should be easy.
You'll need to strip the seats, console, and all carpeting to get to it all. I wouldnt worry too much about the deadeing on the firewall, that was hard enough to get to without having the dash on.
I really doubt that someone already took it out beause for the hassle that it is there really isnt much of a benefit at all. Id be shocked to see it just pull up by hand. I had to take a torch to it and then scrape it of before it budged. This wont be easy.
The plug under the Passenger side seat in a 2G is the factory Infinty amp that cam in some of the AWD models. It might have been an option in the FWDs and the Spyders. It was the Infinity Gold 6 or 8 speaker system I believe.
1 - 20 of 22 Posts
