21 - 29 of 29 Posts
vroom4 said:
should i check the bearings? And how do u go about that
From the sound of it, you should take the car to a shop and let them do the work. Doing your own work is great and lighter on the wallet, but shouldn't be done without experience or with someone that is certified.
Discussion starter · #22 ·
this is a learning experience. im very capable of just swapping in a 6 bolt which is probably what ill end up doing anyway. its not like the work is "hard" its just learning what needs to be done.
so no, i will not be taking it to a mechanic thanks for the suggestion though ill keep it in mind:)
Why don't you check the convertor area as previously mentioned? You could jack the front of the car up if you dont have a lift, and put a breaker bar into the crank pully bolt. Turn the the engine back and forth with the bar and listen underneath where the dust shield is missing. At least you will know if it is indeed your flexplate or convertor bolts or not. Believe me, when they are loose the plate makes a hell of a racket that sounds like a bad rod knock.
Matter of fact since the shield is already off, just take a 17mm wrench and try to turn one of the convertor bolts. If it is loose then, Bingo!
Im in that exact problem you are right now......my torque converter bolts came up loose and im hoping that's the problem.....i just dont understand how would they make that sound.... it goes they same direction.....wouldn't they have to rotate clockwise and counter-clockwise in order to make a sound?
Discussion starter · #25 ·
Ill try it tonight. thank you. hopefully that is it and ill save myself some time and money
vroom4 said:
this is a learning experience. im very capable of just swapping in a 6 bolt which is probably what ill end up doing anyway. its not like the work is "hard" its just learning what needs to be done ...
Sorry, I didn't mean to make it sound like I was talking you down :eek:
Yes, it is definitely a learning experience :)
This is a buddy of mines car...
99 AT GSX w 6bolt.
First here is the gear you are seeing and those are the common bolts to come loose. Also the plate itself may be cracked.
The circular mark on the block is where the bolt heads hit the plate
Discussion starter · #29 ·
So the problem isss...
One of the piston rod connecting bearings is totally missing. after a little examination i found that a few of the journals(sp?) are a little scored along with some bad bearings.
The cylinder walls seam to be alright.
Next step is pulling the rusted on hubs off,removing transaxle,and pulling motor/trans.
Since its pretty likely that the spun bearings are caused by broken down oil, not a misperfection in the block itself, im going to reuse it in my rebuild. Also because this is an auto. Anyone see any harm in machining the crank and replacing the bearings?
21 - 29 of 29 Posts
