1 - 14 of 14 Posts
larc
I accidently left my manual In Anacortes, WA while visiting my brother/friends and yes I searched.
Need to know the torque specs for the plugs.
Also if anyone knows of an online manual for 1g's please post the link.
VFAQS search is broken right now and seems to be broken more than it is working :(
Thanks in advance
Ok, cool. This won't have any negative long-term effects correct?
I havnt experience any negative effects at all. I hoe im not wrong here but this is what I was always tought and have done.
Just DONT over tighten them or leave them too loose. Know what Im sayin?
I do indeed, thanks for the info sir.
Torque on plugs? Just make sure they are good and tight and you'll be fine.
Discussion starter · #9 ·
K awesome, 19lbs it is. Thanks
I usually swap them every time I do major changes to my car or my tune...Ive had like 4-5 sets of NGK plugs in about 10k miles....
The process I use, is hand tightening them with an extension, and after that is hand tight, I give it a few torques from a ratchet...I know if it's too loose if I come back the next day and they have loosened themselves...Just another couple torques and no problemo
-Josh
1 - 14 of 14 Posts
