Here, since its a street car and presumeably pump gas. Hoping its 93+ where you are...
I'd say go with a stg 5 turbine housing 50 trim. It'll spool slower but rip on top and give you just enough headroom to crack the 450ish mark possibly on pump gas. Likely around 26ish psi. I would suggest link, a 255 rewired, 6an the whole way from the tank back, stock rail just machine it out and screw the fittings in. Cams shoot the middle on a street car, fp2's/272's etc. Single spring kit should work, might have to shim if you're revving high. (If you are going to rev to the moon go with fp's dual spring kit and fuck shimming anything. Go with a good IM, JMF, or magnus. Grab a set of 880's+ if you're using link. Maybe 950's in your case. And save the nitrous controls for a h20/meth inj kit. That should help you beat the need for race gas and allow you to fully implement a gt 30/35r. IC of your choosing. Internals are up to you. I have similar goals and went Mahle/Scat. I liked the light weight factory coated shabang they had going on.
If you are planning on doing it to a 7 bolt you NEED to call overbore. That's pretty much their thing. Mark lives and breathes 7 bolt *cough* garbage. *cough-cough* Ross/Manley Wiseco/whatever... They're all good. Skip eagle rods. Mark will say Scat and Mahle tho. Mainly because they run about 1&8/10th's to 2ish thou piston to wall clearance. Which means excellent street behavior, little blow by and no start up rattle as THEY DO NOT EXPAND AT ALL.
As far as head, you probably won't need them but 1mm o/s valves will help. These can be had for pittance if you know where to look. I use engnbldr . com Ted's a good guy and they're swirl polished stainless for ebay prices. Fuck you can get them, guides, and lifters for under $250. That's what I have now. (And beat the living shit out of)
I like cast exhaust manifolds but thats just me. You choose. A simple ARP/MLS combo should work well for you. I'd probably go mitsu mls. I've reused mine twice now and it doesn't push a drop. To minimize port work I'd consider a 1g head and pretty much leave it be. Again, up to you.
If that doesn't net you atleast 450hp you're a fucking idiot.
Clutch, I'd say 2900 w/street disc if you can handle it. Expect to change it once a season if you race alot. Or spend big bucks and go twin disc.
Again... up to you.
Any more brain busters?
