first off, you came in and gave him advice to go buy another oem pcv valve after he had already stated that he had replaced it about 4 months ago... which, yes, IS just a suggestion, however, it is a poor suggestion. if you think that replacing a pcv valve every few months is better than fixing it with a PROVEN TO WORK method, more power to you, i guess... im just trying to help him get it fixed so he wont have to worry about it anymore.
then, i gave him an answer for a solution that will work and is backed by pretty much the whole 'dsm wisemen' community and you come in and tell me to 'kiss your ass' because i told you that your suggestion was not the best answer? and i was the one who started the retarded comments? looks like hukt on foniks worked wonders for you.
whatever, dipshit... i know that you havent done the research to be able to argue with me about this.. let alone have first hand experience with dealing with the setup. this is in no way a 'home depot hack job' and i am offering him good advice... so again, unless you offer some solid information here on WHY the stock pcv valve is a better option than this 'hack job' setup.. keep your opinions to yourself or just PM me. no need in cluttering up his thread with your worthless opinions.
