So it has been an extremely long time since I've had my car up and running, I haven't had it since last September and I have been working on my build up. I finally got my block and everything back from the machine shop yesterday after they had it for almost 3 months:wall:. I got it back and started to mess around with everything. I painted the block and got ready to put the main bearings in, but found out the ACL bearings I ordered a couple months ago where the wrong ones and I was given 7 bolt and not 6 bolt
. As of now I am just waiting on the exchange of the bearings and deciding what I want to gap the rings at. Hopefully I can wrap up this long process this week:banana: . So to no further adieu heres everything that is going into the build, I'll call it a diary of pics.
Block
Bored .020 Over
Eagle 100mm Crank
Pauter Rods
CP Coated Pistons
B/S Removed
ARP Main and Head Studs
ACL Race Main/Rod Bearings
New OEM Oil/Water Pump
New OEM T-Belt and Pulleys
OEM Gasket Kit
Head
New OEM Valve Guides
Gasket Matched
Ran out of money for cams/valve springs:wall:
Air/Fuel/Ignition
FP3065
JMF Race SMIM
Q45 TB
XSPower Core w/ 3" UICP 2.5" LICP
3" GM MAF
K&N 4" Filter
COP
NGK BPR7ES
1000cc PTE Injectors
Walby 255
10mm Fuel Line from tank to rail
K&N Fuel Filter
Aeromotive AFPR
Tuning
DSM Link
GM Maft
Autometer Oil Pres/Boost/Water Temp
NGK AFX Wideband
Greddy FATT
Miscellaneous
Evo 3 Mani
Fluidamper
Hallman BC
Tial BOV
Tial WG
FP 2.5" O2 Housing
Megan DP
Thermal R&D 3" Exhaust
4 Bolt Rear
KYB AGX/Eibach Sportline Springs/Struts
I believe that's all but I'm probably forgetting something, time for the pics!
The Talon before it was torn down, notice the smoke it wasn't cold. The front bumper looks like absolute shit!
And now the tear down, draining all the fluids.
Taking off the front bumper and intercooler.
3065
Now taking out the axles and other random things and harness plugs.
Fast forward, everything is disconnected, axles and T-case are out, only thing left is to pull the motor!
I shouldn't of lifted from the mount bracket by the T-belt it made a bad angle but I had no brackets left.
No more motor
Next morning, time to start tearing it down.
Tour everything off of it and took it all to the machine shop, time for some engine bay prep. I used Aircraft stripper to break it all loose scraped everything and sanded then washed it down. While I was doing that I mended so broken wires and taped everything up nicer.
Finished product.
Block
Bored .020 Over
Eagle 100mm Crank
Pauter Rods
CP Coated Pistons
B/S Removed
OEM Gasket Kit
Head
Gasket Matched
Air/Fuel/Ignition
FP3065
JMF Race SMIM
Q45 TB
3" GM MAF
K&N 4" Filter
COP
NGK BPR7ES
Walby 255
K&N Fuel Filter
Aeromotive AFPR
Tuning
DSM Link
GM Maft
NGK AFX Wideband
Greddy FATT
Miscellaneous
Evo 3 Mani
Fluidamper
Hallman BC
Tial BOV
Tial WG
FP 2.5" O2 Housing
Megan DP
4 Bolt Rear
3065
No more motor
Finished product.
