Ok long story short doing some tuning on an evo 1. Anyways with stock cams we were able to hit 1.5 bar with about 20 degrees of timing and only about 6-10 counts of knock running 100 octane fuel.
Ok here goes the tricky part. We switched his stock cams in favor of FP1x cams. Now the car reads a linear knock count progression up to 25-29 counts on the logging. It doesn't matter what boost we run or how much timing I pull out of the CAS it reads 25-29 counts consistently in a linear progression. We are also using the Apexi RSM logging back to back. Long story short I am positive the 25-29 counts are not real knock. Its engine noise.
My question is to you guys I have heard of using lots of teflon tape on the knock sensor and re-torquing to a lower spec, to desensitize the knock sensor. How much will this desensitize the knock sensor? As we basically need to reset the baseline to 25 counts.
Any other tricks are anything that people know will desensitze the knock sensor and still retain it in the block? (no zip tieing it to the firewall...thats a bit too dangerous at this point).
thanks.
thanks.
