21 - 38 of 38 Posts
That doesn't look like much reduction. Here was most of my reduction on the pro-kits that's with around 350 pounds weight reduction. The eibach sportlines would be a little lower, but coil overs are the right solution though. I thought the car was very well balanced, and handled better with the reductions that I had done. You just have to focus on how you want the cg of the car to change.
Keep in mind the camera angle actually makes the wheel gap look less than it was
Here's my rre modded koni / GC setup, it could go much lower, but I don't want a car that has to crawl over speed bumps
Discussion starter · #24 ·
Just an update, I am working on getting some more pics/reductions within a day or so. And as for the race seats I did start looking into them. Just dont have the money right now so I havent gotten too serious about them.
^^ Scott, how did you do that front lip on your car. And it looks good, i think some black rims would make it look even better imo.
Anyways yea your gap in that first place is pretty wicket. Mines is probably just as much though because of my weight reduction, I just have bigger tires i think. I need coilovers to get a 2in drop all the way around. These 1.5 H&R are not enough. But yes dropping to low isnt worth it to me either, not to mention too low and you compromise handling anyways with such short strut travel.
The lip was cnc'd from another member years ago, he only made them the one time. I have some polished 5 stars on it now. Some how I didn't put those pictures on the hard drive before moving, so I don't have any angles showing them too well. The tires in the pic were 225/45 R17's.
Discussion starter · #28 ·
Well I have been too busy to really mess with any other weight reduction projects until now. I got a couple pics up of the nearly completed after...
Shows height from kneeling down to take a pic. Mind you the top end is off and the car has small wheels and tires. Fronts are 205/50R15, Rear 195/60R15.
Finished front, would look good with race seats. :D
The finished rear minus the two black patches left and right. Pic is pwnd by the cheap gaskets :(
All of them need to be the same overall diameter on awd vehicles. Same size is easiest.
Your rears are aproximately 19.78" in diameter. The fronts are aproximately 19.2" in diameter.
I would say they are fine based on that they are within 5% of eachother. Of course this can be off if the rear wear faster than the front or vice versa. Being within 5% is the number we always used when doing tires at my jobs. That is also the number goodyear uses for awd or 4wd vehicles.
Discussion starter · #32 ·
Yeah, I planned on getting them matched before the car goes back on the road. I thought he meant for some reason that they couldent be that small or something but after I posted I remembered that AWD cars, at least I thought, had to have the same size tires all the way around. I really wish I could get some 17's but thats out of the question for now and even though they are 15's at least they are Momo's. Thanks for pointing the 5% thing out as well. I never knew that.
scotthidley said:
Ignore the 5% rule. It isn't in the owners manual, it isn't advertised by Chrysler, and last time I checked, Good Year made tires and other products but no trannies, axles, or differentials.
That's true. But, goodyear and all the other places I have workeed including a Mitsubishi dealer are reponsible if something happens to thoe parts due to the tires.
No they aren't. If you put the wrong size tires on your car, then it's your own fault. Typically companies are only liable for the replacement costs of their own parts, not any others damaged (that's assuming a warranty is even included). If this weren't the case, I'd have a new TRE race tranny as the Quaife Center diff caused the failure. Instead I'm out 5k, and have a bunch of broken parts. Dealers are liable for damage they cause to your car for any damage resulting from their work. Their parts warranty is typically only 12k miles, while the same part from the factory had a 36k mile or more warranty. Even then when you try to claim warranty it's easy enough for the company to say that failure was caused by something else. So with that all said, if warranties are given out, it's often either a practice of the company just trying to take care of it's customers, or just actually honoring the warranty.
I'm not trying to argue with you. Just stating facts from my experiance working with said companies. Every place I worked would refuse to put them on unless they were within 5% of eachother because they knew they were liable if they put them on. NY might be easier to get this stuff to go through since all you have to do is make a complaint at the dmv about the shop. Then the dmv does an investigation. That is how I got my money back from aamco transmission when they locked up the tran for running it with no fluid and said it was my fault. Anyway I know every place I worked would pay for the things if it was their fault. And I'm done trying to prove a point about facts.
21 - 38 of 38 Posts
