Okay, so even before I did the 16G swap, I've had a high idle problem, but it was come and go.
So now I have a 1G TB, BISS screw is bottomed out, TPS is adjusted, replaced the IAC motor because it was bad, and have not a single boost leak. So before anyone says one of those is the problem, apparently it isn't, because I'm still sitting at 1500-2000 RPM at idle. Stock cams.
My question is, what on earth would cause this?
NO boost leaks
TPS adjusted
BISS bottomed out
IAC motor is good
1G TB hooked up the same as the 2G TB was, extra nipple is capped off.
Someone help so I can drive my car and try out my new turbo!
:dunno:
NO boost leaks
TPS adjusted
BISS bottomed out
IAC motor is good
