I tried to fiberglass the hole by stretching the material tight but it eventually sags while drying, I also tried to back the material with insulation foam but the foam shrunk and the fiber glassed sagged again while drying.
I'm generally confused as to what the best way to go about this would be. I would just make a mold if I had another 2g, but I dont.
Also, how many layers of fiber glass should I use? How much resin for each sheet? It seems the more resin I use the harder the fiberglass, ofcourse.
